powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / Oracle Forms [игнор отключен] [закрыт для гостей] / Проблема при запуске forms и reports на weblogic'e
    #36911491
Фотография Sayan Malakshinov
При попытке запустить что Forms, что Reports возникает такая ошибка:
WLS_FORMS.log
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
 < 1287620411211 > <BEA- 149061 > <Module dms.war of application DMS Application [Version= 11 . 1 . 1 . 1 . 0 ] failed to transition from STATE_NEW to STATE_PREPARED on server WLS_FORMS.>
####< 21 . 10 . 2010   9 : 20 : 11  IRKST> <Error> <Deployer> <crm.uucn.ru> <WLS_FORMS> <[STANDBY] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> < 1287620411216 > <BEA- 149265 > <Failure occurred in the execution of deployment request with ID '1287620410903' for task '0'. Error is: 'java.lang.NoClassDefFoundError: oracle/dms/http/Request'
        at java.lang.Class.getDeclaredFields0(Native Method)
        at java.lang.Class.privateGetDeclaredFields(Class.java: 2291 )
        at java.lang.Class.getDeclaredFields(Class.java: 1743 )
        at weblogic.j2ee.dd.xml.BaseJ2eeAnnotationProcessor.getFields(BaseJ2eeAnnotationProcessor.java: 1024 )
        at weblogic.j2ee.dd.xml.BaseJ2eeAnnotationProcessor.getFields(BaseJ2eeAnnotationProcessor.java: 1017 )
        at weblogic.j2ee.dd.xml.BaseJ2eeAnnotationProcessor.processJ2eeAnnotations(BaseJ2eeAnnotationProcessor.java: 98 )
        at weblogic.j2ee.dd.xml.J2eeAnnotationProcessor.processJ2eeAnnotations(J2eeAnnotationProcessor.java: 37 )
        at weblogic.servlet.internal.WebAnnotationProcessorImpl.processServlets(WebAnnotationProcessorImpl.java: 226 )
        at weblogic.servlet.internal.WebAnnotationProcessorImpl.processJ2eeAnnotations(WebAnnotationProcessorImpl.java: 209 )
        at weblogic.servlet.internal.WebAnnotationProcessorImpl.processAnnotations(WebAnnotationProcessorImpl.java: 105 )
        at weblogic.servlet.internal.WebAppServletContext.processAnnotations(WebAppServletContext.java: 1359 )
        at weblogic.servlet.internal.WebAppServletContext.<init>(WebAppServletContext.java: 440 )
        at weblogic.servlet.internal.WebAppServletContext.<init>(WebAppServletContext.java: 484 )
        at weblogic.servlet.internal.HttpServer.loadWebApp(HttpServer.java: 418 )
        at weblogic.servlet.internal.WebAppModule.registerWebApp(WebAppModule.java: 976 )
        at weblogic.servlet.internal.WebAppModule.prepare(WebAppModule.java: 381 )
        at weblogic.application.internal.flow.ScopedModuleDriver.prepare(ScopedModuleDriver.java: 176 )
        at weblogic.application.internal.flow.ModuleListenerInvoker.prepare(ModuleListenerInvoker.java: 199 )
        at weblogic.application.internal.flow.DeploymentCallbackFlow$ 1 .next(DeploymentCallbackFlow.java: 507 )
        at weblogic.application.utils.StateMachineDriver.nextState(StateMachineDriver.java: 41 )
        at weblogic.application.internal.flow.DeploymentCallbackFlow.prepare(DeploymentCallbackFlow.java: 149 )
        at weblogic.application.internal.flow.DeploymentCallbackFlow.prepare(DeploymentCallbackFlow.java: 45 )
        at weblogic.application.internal.BaseDeployment$ 1 .next(BaseDeployment.java: 1221 )
        at weblogic.application.internal.BaseDeployment.prepare(BaseDeployment.java: 367 )
        at weblogic.application.internal.SingleModuleDeployment.prepare(SingleModuleDeployment.java: 43 )
        at weblogic.application.internal.DeploymentStateChecker.prepare(DeploymentStateChecker.java: 154 )
        at weblogic.deploy.internal.targetserver.AppContainerInvoker.prepare(AppContainerInvoker.java: 60 )
        at weblogic.deploy.internal.targetserver.operations.ActivateOperation.createAndPrepareContainer(ActivateOperation.java: 207 )
        at weblogic.deploy.internal.targetserver.operations.StartOperation.createAndPrepareContainer(StartOperation.java: 88 )
        at weblogic.deploy.internal.targetserver.operations.StartOperation.doPrepare(StartOperation.java: 101 )
        at weblogic.deploy.internal.targetserver.operations.AbstractOperation.prepare(AbstractOperation.java: 217 )
        at weblogic.deploy.internal.targetserver.DeploymentManager.handleDeploymentPrepare(DeploymentManager.java: 747 )
        at weblogic.deploy.internal.targetserver.DeploymentManager.prepareDeploymentList(DeploymentManager.java: 1216 )
        at weblogic.deploy.internal.targetserver.DeploymentManager.handlePrepare(DeploymentManager.java: 250 )
        at weblogic.deploy.internal.targetserver.DeploymentServiceDispatcher.prepare(DeploymentServiceDispatcher.java: 159 )
        at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer.doPrepareCallback(DeploymentReceiverCallbackDeliverer.java: 171 )
        at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer.access$ 000 (DeploymentReceiverCallbackDeliverer.java: 13 )
        at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer$ 1 .run(DeploymentReceiverCallbackDeliverer.java: 46 )
        at weblogic.work.SelfTuningWorkManagerImpl$WorkAdapterImpl.run(SelfTuningWorkManagerImpl.java: 528 )
        at weblogic.work.ExecuteThread.execute(ExecuteThread.java: 201 )
        at weblogic.work.ExecuteThread.run(ExecuteThread.java: 173 )
Caused By: java.lang.NoClassDefFoundError: oracle/dms/http/Request
В чем может быть дело? Я ничего не удалял.
И еще один идиотский вопрос: как "на лету" переключать режимы developement-production?
Модератор: Тема перенесена из форума "Oracle".
