FRM - 92101
Привет. При запуске формы появляется ошибка FRM-92101: There was a failure in the Forms Server during sturtup.... ("Скрин" во вложении). Ошибка возникает с непонятной периодичностью. Заранее спасибо. Лог сервера содержит следующее: Loading http://tvs1002-vm1002:8889/forms/java/frmall_jinit.jar from JAR cache Loading http://tvs1002-vm1002:8889/forms/java/frmwebutil.jar from JAR cache Loading http://tvs1002-vm1002:8889/forms/java/jacob.jar from JAR cache proxyHost=null proxyPort=0 connectMode=HTTP, native. ?????? ??????? Forms: 10.1.2.0 java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed. at sun.applet.AppletClassLoader.getBytes(Unknown Source) at sun.applet.AppletClassLoader.access$100(Unknown Source) at sun.applet.AppletClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at oracle.forms.handler.UICommon.instantiate(Unknown Source) at oracle.forms.handler.UICommon.onCreate(Unknown Source) at oracle.forms.handler.JavaContainer.onCreate(Unknown Source) at oracle.forms.engine.Runform.onCreateHandler(Unknown Source) at oracle.forms.engine.Runform.processMessage(Unknown Source) at oracle.forms.engine.Runform.processSet(Unknown Source) at oracle.forms.engine.Runform.onMessageReal(Unknown Source) at oracle.forms.engine.Runform.onMessage(Unknown Source) at oracle.forms.engine.Runform.sendInitialMessage(Unknown Source) at oracle.forms.engine.Runform.startRunform(Unknown Source) at oracle.forms.engine.Main.createRunform(Unknown Source) at oracle.forms.engine.Main.start(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source) oracle.forms.net.ConnectionException: ????? Forms <5> ???????: ?????????? ????? ??????? ? ??????????? ?????????. at oracle.forms.net.ConnectionException.createConnectionException(Unknown Source) at oracle.forms.net.HTTPNStream.getResponse(Unknown Source) at oracle.forms.net.HTTPNStream.doFlush(Unknown Source) at oracle.forms.net.HTTPNStream.flush(Unknown Source) at java.io.DataOutputStream.flush(Unknown Source) at oracle.forms.net.StreamMessageWriter.run(Unknown Source) ... |
| 22.02.2012, 13:35 |
FRM - 92101
archarmon, FRM-92101: Session-binding not enabled (see also FRM-92050) Unhandled exception in Forms runtime Unhandled exception in server JVM (OC4J) Application uses imported java, but is unable to access server side JDK/JRE Forms not recompiled with COMPILE_ALL option FORMS_TIMEOUT set to a value smaller than HEARTBEAT Unable to start Forms Runtime (frmweb). Usually the result of insufficient resources (i.e. file descriptors, swap, desktop heap, etc.) Attempting to start form more than one time in the same browser session ORACLE_HOME or FORMS variable incorrectly set in default.env (or custom .env) .. возможно ещё поможет патч форм - 10.1.2.3 ... |
| 24.02.2012, 09:06 |
start [/forum/topic.php?fid=51&gotonew=1&tid=1878527]: |
37ms |
23ms |
| others: | 211ms |
| total: | 308ms |
