Oracle XML DB HTTP listener with the embedded PL/SQL gateway
Есть вот такая шняга: The structure of the link to the Application Express administration services is as follows: (Oracle HTTP Server with mod_plsql) http://host:port/pls/apex/apex_admin (Oracle XML DB HTTP listener with the embedded PL/SQL gateway) http://host:port/apex/apex_admin The structure of the link to the Application Express development interface is as follows: (Oracle HTTP Server with mod_plsql) http://host:port/pls/apex (Oracle XML DB HTTP listener with the embedded PL/SQL gateway) http://host:port/apex Так вот. Вот это: http://host:port/pls/apex/apex_admin http://host:port/pls/apex РАБОТАЕТ. А вот это: http://host:port/apex/apex_admin http://host:port/apex НЕТ. А именно: File does not exist: $APACHE_HOME/Apache/Apache/htdocs/apex/apex Как это настроить? Я не понимаю. ... |
| 25.12.2008, 16:07 |
start [/forum/topic.php?fid=50&gotonew=1&tid=1877544]: |
90ms |
49ms |
| others: | 236ms |
| total: | 439ms |
