Ошибки на работающих страницах, созданных в АрЕх
как сделать чтоб на веб-странице при ошибке не выводилось типа???: _______________________________________________________________ 0Invalid function body condition: ORA-06550: line 1, column 47: PLS-00103: Encountered the symbol "=" when expecting one of the following: ( - + case mod new not null avg count current exists max min prior sql stddev sum variance execute forall merge time timestamp interval date pipe _______________________________________________________________ Invalid function body condition: ORA-06550: line 1, column 47: PLS-00103: Encountered the symbol "=" when expecting one of the following: ( - + case mod new not null avg count current exists max min prior sql stddev sum variance execute forall merge time timestamp interval date pipe Invalid function body condition: ORA-06550: line 2, column 4: PLS-00103: Encountered the symbol "=" when expecting one of the following: ( - + case mod new not null avg count current exists max min prior sql stddev sum variance execute forall merge time timestamp interval date pipe _______________________________________________________________ ... |
| 03.04.2009, 03:47 |
Может, просто стоит исправить ошибки? ... |
| 03.04.2009, 09:07 |
start [/forum/topic.php?fid=50&gotonew=1&tid=1877436]: |
69ms |
27ms |
| others: | 219ms |
| total: | 363ms |
