APEX 4.0 Early Adopter
heavysideБеглый взгляд, всё-таки была уже ночь после тяжелого дня, обнаружил websheets ) Было бы странно, если бы Вы их не обнаружили - это всё-таки milestone для Phase II. :) ... |
| 04.03.2010, 11:39 |
скока ещё будет "Phase" до релиза? есть ли инфа насчёт платности? а то всё же там AnyChart 5-ая версия... ... |
| 04.03.2010, 15:45 |
Legi, 0. Без понятия, но предчувствие говорит как минимум ещё об одной. Security должны подтянуть. :) 1. Думаю, использование AnyChart 5.1 в APEX 4 будет аналогично использованию AnyChart 3/4 в APEX 3. То есть, бесплатно. 2. Зацитирую неполный список новых фич из YABAOAE : http://joelkallman.blogspot.com/2010/02/application-express-40-early-adopter.html # This database was created with database character set AL32UTF8 (we're still a little confused by the Amazon Machine Images from Oracle aren't already AL32UTF8. # The Websheets feature is now available. The security of Websheet applications still needs to be refined, but the functionality and ease of creation of these types of applications is amazing. # The new tree region makes its debut. # Collections now support NUMBER and DATE # apex_collection.create_collection_from_query_b and apex_collection.create_collection_from_queryb2 support bind variables and row limits # Debugging and logging has been completely rewritten - no longer is debug output emitted within the page, but it's collected and can be viewed later (and also queried via views). # You won't be able to see this, but the tablespaces / data files of provisioned workspaces will now autoextend # There have been many improvements in the Plug-In infrastructure, which Patrick will surely expand upon. # A Migration Assistant has been created, which lets you upgrade all of the elements of your pre APEX 4.0 application in one place. # Native validations and declarative validations have also been rewritten and improved (again, Patrick will expand upon this). # All of the item types have been consolidated (so you no longer see 1,000 different Date Picker types in your item type select list, as well as other item types) # A large number of bugs and usability issues have been corrected, thanks in a large part to the tremendous amount of feedback we received. ... |
| 04.03.2010, 16:24 |
suPPLerAlexvmkна бесплатной версии есть возможность стандартными средствами APEX выводить отчеты в формате pdf, rtf, xls? APEX сам по себе бесплатен. Вы имеете в виду, выводить из приложений на сервере apex.oracle.com? Нет. Как я понял, на бесплатной версии нельзя в форматы pdf, rtf, xls выводить отчеты интерактивные. или я ошибаюсь?! Будт ли что-то в 4-ке по этому поводу нового? ... |
| 12.03.2010, 16:52 |
AlexvmkНет. Как я понял, на бесплатной версии нельзя в форматы pdf, rtf, xls выводить отчеты интерактивные. или я ошибаюсь?! Вы ошибаетесь. :) APEX может использовать в качестве сервера печати отчётов какое-либо решение. Платное (e.g. Oracle BI Publishing), бесплатное (e.g. Tomcat + FOP). Советую почитать PDF Printing in Application Express . AlexvmkБудт ли что-то в 4-ке по этому поводу нового? Я пока не в курсе. :) Ещё не закончились этапы открытого тестирования, и нет доступной для скачивания и установки версии APEX 4.0. ... |
| 12.03.2010, 17:01 |
suPPLerAlexvmkНет. Как я понял, на бесплатной версии нельзя в форматы pdf, rtf, xls выводить отчеты интерактивные. или я ошибаюсь?! Вы ошибаетесь. :) APEX может использовать в качестве сервера печати отчётов какое-либо решение. Платное (e.g. Oracle BI Publishing), бесплатное (e.g. Tomcat + FOP). Советую почитать PDF Printing in Application Express . AlexvmkБудт ли что-то в 4-ке по этому поводу нового? Я пока не в курсе. :) Ещё не закончились этапы открытого тестирования, и нет доступной для скачивания и установки версии APEX 4.0. Про это все я слышал. Для 1 варианта печати нужно покупать Oracle BI Publishing, а для второго нужно бубном много играться:) То есть простого решения нет без затрат денег. ... |
| 12.03.2010, 17:03 |
AlexvmkДля 1 варианта печати нужно покупать Oracle BI Publishing, а для второго нужно бубном много играться:) То есть простого решения нет без затрат денег. As always. Либо Вы делаете что-то сами, либо это что-то делают за Вас, но не бесплатно. :) ... |
| 12.03.2010, 17:06 |
Up! Обещанный EA 3 уже есть. Если всё будет хорошо, то за ним состоится выпуск релиза APEX 4.0... ;) ... |
| 11.05.2010, 01:15 |
Legi, тынц: http://dpeake.blogspot.com/2010/05/apex-40-early-adopter-iii-ea3-now-live.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+dpeake+%28David+Peake+on+Oracle+APEX%29 David Peake on Oracle APEX APEX 4.0 Early Adopter III (EA3) now live! As we speed down our development path towards production release (in Calendar Year 2010) we have reached yet another milestone - Roll-out of Early Adopter III. Simply go to tryapexnow.com This is our last planned version of the Early Adopter and includes many new features, numerous bug fixes, and a more refined user interface. As with when we rolled out EA2, everyone will need to request a new workspace. The old EA2 ( http://184.73.244.154/apex ) will be available for a few weeks to allow people to recover what they need from the old environment. You may experience issues with exporting from EA2 and importing into EA3. We have found some issues with applications including charts. This is primarily due to changes in the chart export parameters and will not impact applications exported from earlier releases (APEX 3.2 etc). Enjoy our latest offering and please keep the feedback coming. We do read them and try to respond when we can. Regards, David ... |
| 11.05.2010, 14:01 |
Я надеюсь, все заметили переезд APEX 4.0 на apex.oracle.com ? :) ... |
| 08.06.2010, 19:06 |
о как... я так понимаю апдейт ещё не выложили в паблик? ... |
| 08.06.2010, 21:54 |
ууурраа... там AnyChart 5.0. в графиках !!!! ... |
| 08.06.2010, 22:21 |
Legi, если под апдейтом понимается публичный релиз-кандидат, то он уже есть, достаточно запросить себе рабочее пространство. Если же под ним имеется в виду загружаемый для установки релиз-кандидат - нет, такого вроде нет. :) ... |
| 08.06.2010, 22:24 |
Legiууурраа... там AnyChart 5.0. в графиках !!!! Вроде уже было, причём, с первого EA. Тем не менее, рад, что добрались пощупать. :) ... |
| 08.06.2010, 22:28 |
про графики там вроде как тестовый вариант был... а тут вот оно :) насчёт апдейта.. я имел ввиду именно даунлодный вариант.. т.е. скачать и дома проапгрейдить :) по информацию от зарубежных колег такой релиз ожидается в конце июня, вначале июля... вообщем ждёмс :) но уже радует, что полноценно можно поюзать :) ... |
| 08.06.2010, 23:38 |
start [/forum/topic.php?fid=50&gotonew=1&tid=1876934]: |
149ms |
59ms |
| others: | 242ms |
| total: | 499ms |
