BIP и saw.dll
Здравствуйте. У меня проблема с этим saw.dll. Он не хочет работать, при любом действии выдает ошибку. 500 Servlet error: An exception occurred. The current application deployment descriptors do not allow for including it in this response. Please consult the application log for details. В логах смотрел но ничего не понял. [quote- The class java.lang.Throwable is defined in a java or javax package and cannot be converted into an xml schema type. An xml schema anyType will be used to de fine this class in the wsdl file. - The class java.io.InputStream is defined in a java or javax package and cannot be converted into an xml schema type. An xml schema anyType will be used to de fine this class in the wsdl file. - The class oracle.apps.xdo.servlet.resources.Resource does not contain a defaul t constructor, which is a requirement for a bean class. The class cannot be con verted into an xml schema type. An xml schema anyType will be used to define th is class in the wsdl file. [083112_063724037][][EXCEPTION] javax.naming.NamingException: Unresolved naming: cn=adminisrator, dc=user, dc=users, dc=principals at [cn=adminisrator] at oracle.apps.xdo.security.naming.XdoSAXMLCommonFactory.getElementByDN( XdoSAXMLCommonFactory.java:252) at oracle.apps.xdo.security.naming.XdoSAXMLCommonFactory.validateCredent ials(XdoSAXMLCommonFactory.java:285) at oracle.apps.xdo.security.naming.XdoSAXMLCtxFactory.getInitialContext( XdoSAXMLCtxFactory.java:45) at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:6 67) at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:247 ) at javax.naming.InitialContext.init(InitialContext.java:223) at javax.naming.InitialContext.<init>(InitialContext.java:197) at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.jav a:82) at oracle.apps.xdo.security.DirectoryValidator.validate(DirectoryValidat or.java:95) at oracle.apps.xdo.security.XdoSAValidator.validateInternal(XdoSAValidat or.java:67) at oracle.apps.xdo.security.XdoSAValidator.validate(XdoSAValidator.java: 43) at oracle.apps.xdo.servlet.security.SecurityManagerImpl.getLocalPrincipa l(SecurityManagerImpl.java:605) at oracle.apps.xdo.servlet.security.SecurityManagerImpl.getPrincipal(Sec urityManagerImpl.java:367) at _login._jspService(_login.java:175) at com.orionserver.http.OrionHttpJspPage.service(OrionHttpJspPage.java:5 9) at oracle.jsp.runtimev2.JspPageTable.service(JspPageTable.java:453) at oracle.jsp.runtimev2.JspServlet.internalService(JspServlet.java:591) at oracle.jsp.runtimev2.JspServlet.service(JspServlet.java:515) at javax.servlet.http.HttpServlet.service(HttpServlet.java:856) at com.evermind.server.http.ResourceFilterChain.doFilter(ResourceFilterC hain.java:64) at oracle.apps.xdo.servlet.security.SecurityFilter.doFilter(SecurityFilt er.java:191) at com.evermind.server.http.ServletRequestDispatcher.invoke(ServletReque stDispatcher.java:621) at com.evermind.server.http.ServletRequestDispatcher.forwardInternal(Ser vletRequestDispatcher.java:368) at com.evermind.server.http.HttpRequestHandler.doProcessRequest(HttpRequ estHandler.java:866) at com.evermind.server.http.HttpRequestHandler.processRequest(HttpReques tHandler.java:448) at com.evermind.server.http.HttpRequestHandler.serveOneRequest(HttpReque stHandler.java:216) at com.evermind.server.http.HttpRequestHandler.run(HttpRequestHandler.ja va:117) at com.evermind.server.http.HttpRequestHandler.run(HttpRequestHandler.ja va:110) at oracle.oc4j.network.ServerSocketReadHandler$SafeRunnable.run(ServerSo cketReadHandler.java:260) at com.evermind.util.ReleasableResourcePooledExecutor$MyWorker.run(Relea sableResourcePooledExecutor.java:303) at java.lang.Thread.run(Thread.java:595) [083112_063724037][][ERROR] javax.naming.NamingException: Unresolved naming: cn= adminisrator, dc=user, dc=users, dc=principals at [cn=adminisrator] at oracle.apps.xdo.security.naming.XdoSAXMLCtxFactory.getInitialContext( XdoSAXMLCtxFactory.java:49) at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:6 67) at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:247 ) at javax.naming.InitialContext.init(InitialContext.java:223) at javax.naming.InitialContext.<init>(InitialContext.java:197) at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.jav a:82) at oracle.apps.xdo.security.DirectoryValidator.validate(DirectoryValidat or.java:95) at oracle.apps.xdo.security.XdoSAValidator.validateInternal(XdoSAValidat or.java:67) at oracle.apps.xdo.security.XdoSAValidator.validate(XdoSAValidator.java: 43) at oracle.apps.xdo.servlet.security.SecurityManagerImpl.getLocalPrincipa l(SecurityManagerImpl.java:605) at oracle.apps.xdo.servlet.security.SecurityManagerImpl.getPrincipal(Sec urityManagerImpl.java:367) at _login._jspService(_login.java:175) at com.orionserver.http.OrionHttpJspPage.service(OrionHttpJspPage.java:5 9) at oracle.jsp.runtimev2.JspPageTable.service(JspPageTable.java:453) at oracle.jsp.runtimev2.JspServlet.internalService(JspServlet.java:591) at oracle.jsp.runtimev2.JspServlet.service(JspServlet.java:515) at javax.servlet.http.HttpServlet.service(HttpServlet.java:856) at com.evermind.server.http.ResourceFilterChain.doFilter(ResourceFilterC hain.java:64) at oracle.apps.xdo.servlet.security.SecurityFilter.doFilter(SecurityFilt er.java:191) at com.evermind.server.http.ServletRequestDispatcher.invoke(ServletReque stDispatcher.java:621) at com.evermind.server.http.ServletRequestDispatcher.forwardInternal(Ser vletRequestDispatcher.java:368) at com.evermind.server.http.HttpRequestHandler.doProcessRequest(HttpRequ estHandler.java:866) at com.evermind.server.http.HttpRequestHandler.processRequest(HttpReques tHandler.java:448) at com.evermind.server.http.HttpRequestHandler.serveOneRequest(HttpReque stHandler.java:216) at com.evermind.server.http.HttpRequestHandler.run(HttpRequestHandler.ja va:117) at com.evermind.server.http.HttpRequestHandler.run(HttpRequestHandler.ja va:110) at oracle.oc4j.network.ServerSocketReadHandler$SafeRunnable.run(ServerSo cketReadHandler.java:260) at com.evermind.util.ReleasableResourcePooledExecutor$MyWorker.run(Relea sableResourcePooledExecutor.java:303) at java.lang.Thread.run(Thread.java:595) ][/quote] Помогите разобраться. Перезапускать OC4J пробовали, не помогло. Заранее спасибо ... |
| 31.08.2012, 11:23 |
BIP и saw.dll
никто не сталкивался? ... |
| 31.08.2012, 12:32 |
start [/forum/topic.php?fid=50&gotonew=1&tid=1876017]: |
37ms |
50ms |
| others: | 210ms |
| total: | 331ms |
