Подскажите где посмотреть исходный код
В пакете wwv_flow_item есть функция function simple_checkbox ( -- -- Return an HTML form checkbox. Allows to select a simplified checkbox element from a query. -- -- Arguments: -- p_idx = The form element name, e.g. 1 equals f01, 2 equals f02, etc. -- Typically the p_idx argument is constant for a given column. -- p_value = The current value -- p_checked_value = Value returned if checkbox checked -- p_checked_value = Value returned if checkbox unchecked -- p_attributes = Custom HTML arguments added to the HTML input type of checkbox. -- p_item_id = Will set the ID of the item to this value (id="..."). Must be unique! Try concatenating some string with rownum. Required for 508 compliance -- p_item_label = Creates an invisible label for an item. Used for Section 508 Compliance. Class is hideMeButHearMe. -- p_label_template = Optional label template to be used instead of built-in one -- p_before_item = HTML to be printed before the item lable and field -- p_after_item = HTML to be printed after the item lable and field -- -- example(s): -- select wwv_flow_item.checkbox(1,[column name], 'Y') c from [table name] -- p_idx in number, p_value in varchar2 default null, p_checked_value in varchar2 default null, p_unchecked_value in varchar2 default null, p_attributes in varchar2 default null, p_item_id in varchar2 default null, p_item_label in varchar2 default null, p_label_template in varchar2 default null, p_before_item in varchar2 default null, p_after_item in varchar2 default null ) return varchar2; Где можно посмотреть исходный код этой функции? ... |
| 22.08.2013, 12:56 |
loggin, В разврапленном теле. ... |
| 22.08.2013, 14:08 |
start [/forum/search_topic.php?author=%D0%9F%D0%B0%D0%B2%D0%B5%D0%BB+KZ&author_mode=last_topics&do_search=1]: |
28ms |
| others: | 3654ms |
| total: | 3806ms |
