Функция подсчета из разных полей APEX
Есть 3 таблицы Блюда: CREATE TABLE "BLUDES" ( "ID" VARCHAR2(10) NOT NULL ENABLE, "B_NAME" VARCHAR2(64) NOT NULL ENABLE, "B_INGRES" NUMBER, "PRICE" NUMBER, "IMAGE" BFILE, "B_TYPE" NUMBER, CONSTRAINT "BLUDES_PK" PRIMARY KEY ("ID") ENABLE ) / CREATE OR REPLACE TRIGGER "BI_BLUDES" before insert on "BLUDES" for each row begin if :NEW."ID" is null then select "BLUDES_SEQ".nextval into :NEW."ID" from sys.dual; end if; end; / ALTER TRIGGER "BI_BLUDES" ENABLE / Ингредиенты: CREATE TABLE "INGTES" ( "ID" NUMBER, "I_NAME" VARCHAR2(64) NOT NULL ENABLE, "I_DATE" DATE NOT NULL ENABLE, "I_PRICE" NUMBER(6,2) NOT NULL ENABLE, "I_COUNT" NUMBER(7,3) NOT NULL ENABLE, "I_TYPE" NUMBER, CONSTRAINT "INGTES_PK" PRIMARY KEY ("ID") ENABLE ) / CREATE OR REPLACE TRIGGER "BI_INGTES" before insert on "INGTES" for each row begin if :NEW."ID" is null then select "INGTES_SEQ".nextval into :NEW."ID" from sys.dual; end if; end; / ALTER TRIGGER "BI_INGTES" ENABLE / Ингредиенты для блюда CREATE TABLE "INGRES_FOR_BLUD" ( "ID" NUMBER NOT NULL ENABLE, "B_ID" NUMBER, "I_ID" NUMBER, "COUNT" NUMBER, CONSTRAINT "INGRES_FOR_BLUD_PK" PRIMARY KEY ("ID") ENABLE ) / CREATE OR REPLACE TRIGGER "BI_INGRES_FOR_BLUD" before insert on "INGRES_FOR_BLUD" for each row begin if :NEW."ID" is null then select "INGRES_FOR_BLUD_SEQ".nextval into :NEW."ID" from sys.dual; end if; end; / ALTER TRIGGER "BI_INGRES_FOR_BLUD" ENABLE / Нужно написать функцию, которая возвращает цену блюда. ... |
| 09.06.2014, 00:03 |
maukur, И при чем здесь apex ? ... |
| 09.06.2014, 08:54 |
Gustly, А куда поместить? ... |
| 10.06.2014, 01:01 |
start [/forum/topic.php?fid=50&gotonew=1&tid=1875310]: |
39ms |
45ms |
| others: | 224ms |
| total: | 354ms |
