Установка Apex 20.2 на Oracle 12.2.0.1
Никак не удается поставить, ошибку гуглил, но так и не нашел решения. Может кто сможет помочь. SQL> @apexins.sql SYSAUX SYSAUX TEMP /i/ ...set_appun.sql PL/SQL procedure successfully completed. ...set_ufrom_and_upgrade.sql PL/SQL procedure successfully completed. Session altered. FOO3 ------------------------------ install2021-04-07_16-16-07.log . ORACLE . . Application Express (APEX) Installation. .......................................... . ...set_appun.sql ... Checking prerequisites (MANUAL) . . SYSDBA Privilege . pass - Connection with SYSDBA privilege. . Database rolling upgrade . pass - No rolling upgrade. . DB components . pass - CATPROC: version=12.2.0.1.0 . pass - XDB: version=12.2.0.1.0 . XDB . pass - is valid . PL/SQL Web Toolkit . FAIL - Application Express installation requires the PL/SQL Web Toolkit. . Tablespaces . pass - found SYSAUX . pass - found SYSAUX . pass - found TEMP . PHASES (1,2,3)... . . 1 error occurred declare * ERROR at line 1: ORA-20001: Prerequisite checks failed; unable to proceed with APEX installation ORA-06512: at line 291 ... |
| 07.04.2021, 16:24:04 |
стоит windows server 2019 и oracle 12.2.0.1 и все ... |
| 07.04.2021, 16:50:47 |
NikiolosN, Ну, в доках написано "Oracle Application Express requires the PL/SQL Web Toolkit version 10.1.2.0.6 or later. For instructions on determining the current version of the PL/SQL Web Toolkit, and for instructions on installing version 10.1.2.0.6, please review the README.txt file contained in the directory apex/owa." https://docs.oracle.com/cd/E11882_01/install.112/e12196/pre_require.htm#HTMIG384 ... |
| 10.04.2021, 12:00:03 |
start [/forum/topic.php?fid=50&gotonew=1&tid=1873828]: |
186ms |
52ms |
| others: | 247ms |
| total: | 540ms |
