Simple sql convert from int to string .How to do it?
Hi to all. At FoodMart , Time dimension. concat 2 columns "the_month" and "the_year" type of them is "SmallInteger" from table "time_by_day". I try following (at WinSQL) Select "the_year" + ' ' + "the_month" From "time_by_day" It return error. Q1: How to convert from "SmallInteger" to string? Have a good day .Ella. ... |
| 12.01.2003, 16:10 |
I find CStr(). ... |
| 12.01.2003, 16:48 |
Try 'Convert' function ... |
| 13.01.2003, 11:40 |
start [/forum/topic.php?fid=49&gotonew=1&tid=1873602]: |
54ms |
26ms |
| others: | 210ms |
| total: | 336ms |
