SQL -> MDX
Hello, If I want to express the same as the SQL below in MDX: Код: plaintext 1. 2. 3. 4. ... in MDX, would this be a reasonable translation: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. ... or there exists a more elegant expression (in MDX) ? Also, why this MDX produces an error: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. Thanks. ... |
| 09.09.2004, 16:48 |
SQL -> MDX
IMHO вместо "+" надо "," ... |
| 09.09.2004, 22:36 |
SQL -> MDX
<quote> IMHO вместо "+" надо "," </quote> 1. '+' and ',' do the same in this context, namely produce a union of two sets. The real problem is that Measures.mySum does not work while Product.mySum (see the first version) does. You can easily veri 2. Do you have any thoughts on simplifying the sql->mdx translation ? Is it a general approach with MDX that when you want to describe sets defined by more or less arbitrary predicates, you need to use some combination of CrossJoin and Union ? In SQL, you'd just use predicates in the where clause plus joins when necessary. Thanks. ... |
| 09.09.2004, 23:04 |
start [/forum/topic.php?fid=49&gotonew=1&tid=1872263]: |
53ms |
62ms |
| others: | 231ms |
| total: | 403ms |
