Обновление кубов Cognos`a
Добрый день, уважаемые! У меня какая то непонятнка, свзанная с вопросом обновления данных в кубах, построенных средствами Cognos. В нем есть программка Scheduler которая поидее должна както выполнять эту функцию. Порывшись в ней я понял, что она просто выполняет task-ом какой нибудь скрипт. Может ктонибудь на простом примере рассказать, как, например обновить данные в кубе? ... |
| 23.09.2004, 07:57 |
RTFM! Run PowerPlay Transformer in Batch Mode Using Scheduler Description You can schedule PowerPlay Transformer to run in Batch mode at a specific time. For example, you can schedule Transformer to refresh an existing PowerCube at a specific time each day. Before Scheduling PowerPlay Transformer to run in batch mode, the PowerPlay administrator should set up Auto-access to the required data sources. This ensures that authenticator attempts to identify the user via their OS signon, thereby eliminating the need for user interaction. The following procedure describes how to schedule PowerPlay Transformer to run in batch mode. Because the macro will run on your computer, you must leave your computer switched on with Scheduler running in order for the task to execute. Steps 1. Open the Scheduler application window. 2. From the Insert menu, click Task. 3. In the File Name box, type trnsfrmr.exe, the file name of the PowerPlay Transformer executable file. Add the path, if necessary. You can also click Browse to open the File Name dialog box, where you can locate the file. Type the appropriate batch mode switches, and then type the name of the model file. For example, you could type: "trnsfrmr.exe" -n -s "national.pye" 4. Type Transformer Batch Mode in the Description text box to identify the task. 5. Click Timetable to show the Timetable tab (Insert Task dialog box). 6. Select the time at which you want the task to run in the Time box. 7. Set the date for the task to be run in the On box. You must select tomorrow's date for the task to run overnight, as the time has been set after midnight. For example, click the arrow keys to change the date to 22/03/04 (March 22, 2004). 8. If the catalog or the database prompt for user IDs and passwords: • Click Security to show the Security tab (Insert Task dialog box). • Type a user class for the task in the User Class box. • Type the password for the user class in the first User Password box. • If the database supports multiple user IDs, type the database user IDs for the task in the User ID box. • If the database supports multiple user IDs, type the passwords associated with the user IDs in the second User Password box. 9. Click OK. The Insert Task dialog box closes, and the task description appears in the task list in the Scheduled tab (Scheduler application window). 10. Do not close Scheduler. You can click the Minimize button on the top right of the Scheduler application window. Scheduler runs minimized, and Transformer will run at the scheduled time on your computer. взято из schd.pdf ... |
| 23.09.2004, 10:20 |
start [/forum/topic.php?fid=49&gotonew=1&tid=1872235]: |
46ms |
37ms |
| others: | 228ms |
| total: | 351ms |
