Ошибка при создании Linked Server к MSAS2008
MS SQL Server 2008 x64 SP2 (Database Engine, Analysis Services) Создаю linked server с сервера, где установлен Database Engine, на сервер с Analysis Services в пределах одного домена. Вот скрипт из окна создания Linked Server: EXEC master.dbo.sp_addlinkedserver @server = N'TEST', @srvproduct=N'MSOLAP', @provider=N'MSOLAP', @datasrc=N'MyCubeServerName', @catalog=N'MyCubeDatabaseName' GO GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'collation compatible', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'data access', @optvalue=N'true' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'dist', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'pub', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'rpc', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'rpc out', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'sub', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'connect timeout', @optvalue=N'0' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'collation name', @optvalue=null GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'lazy schema validation', @optvalue=N'false' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'query timeout', @optvalue=N'0' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'use remote collation', @optvalue=N'true' GO EXEC master.dbo.sp_serveroption @server=N'TEST', @optname=N'remote proc transaction promotion', @optvalue=N'true' GO EXEC master.dbo.sp_addlinkedsrvlogin @rmtsrvname = N'TEST', @locallogin = NULL , @useself = N'False', @rmtuser = N'X\Mylogin', @rmtpassword = N'mypassword' GO Получаю сообщение: The linked server has been created but failed a connection test. Do you want to keep the linked server? ------------------------------ ADDITIONAL INFORMATION: An exception occurred while executing a Transact-SQL statement or batch. (Microsoft.SqlServer.ConnectionInfo) ------------------------------ Cannot set the initialization properties for OLE DB provider "MSOLAP" for linked server "TEST". OLE DB provider "MSOLAP" for linked server "TEST" returned message "The following system error occurred: .". (Microsoft SQL Server, Error: 7373) For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&ProdVer=10.00.4000&EvtSrc=MSSQLServer&EvtID=7373&LinkId=20476 ------------------------------ Подключение к локальному сервису Analysis Services работает отлично. Пробовал, но не помогло: 1) Подключиться к Analysis Service 2008 x32. 2) Отключить Firewall на обоих серверах. Что и как надо настроить для подключения? ... |
| 15.12.2010, 12:31 |
Аналогичная проблема. Кто-нибудь нашёл решение?! ... |
| 19.07.2011, 15:18 |
Попробуйте поставить галку Allow inprocess у провайдера ... |
| 19.07.2011, 15:58 |
Тоже Вылезло Microsoft SQL Server 2012 (SP3-CU1) (KB3123299) - 11.0.6518.0 (X64) Jan 7 2016 14:39:01 Copyright (c) Microsoft Corporation Enterprise Edition (64-bit) on Windows NT 6.1 <X64> (Build 7601: Service Pack 1) (Hypervisor) Причем 2-3 дня назад все работало когда я создал линк-севрер на SSAS Теперь тест выдает Cannot set the initialization properties for OLE DB provider "MSOLAP" for linked server "SSAS". OLE DB provider "MSOLAP" for linked server "SSAS" returned message "The following system error occurred: ". (Microsoft SQL Server, Error: 7373) галка Allow inprocess у провайдера стоит. ... |
| 07.06.2019, 11:06 |
добавлю что у себя на localhost я создал EXEC master.dbo.sp_addlinkedserver @server = N'SSAS2', @srvproduct=N'', @provider=N'MSOLAP', @datasrc=N'VSRV-Cube' и он пашет ОК ... |
| 07.06.2019, 11:19 |
судя по этому http://www.sql.ru/forum/696268/cannot-set-the-initialization-properties-for-ole-db-provider-msolap-for-linked-server баг давний ?? добавлю что создал там же link-server на SSAS на этом же компе и все ОК - тест но мне надо на SSAS на другом - причем 2 дня назад все плаало ок ( т.е какие то сетевые глюки ?? керберос и т.д ) ... |
| 07.06.2019, 11:56 |
обнаружена некоторая корреляция с наличием/отсутствием на соответствующем SQL сервере RDP сессии пользователя, под которым создаётся Linked Server. в нашем случае, ошибка пропадала, когда создавали линк при имеющейся параллельно сессии. но окончательно разобраться в ситуации, пока, не удалось. некоторые детали есть тут и тут ... |
| 29.04.2020, 18:02 |
start [/forum/topic.php?fid=49&gotonew=1&tid=1857327]: |
148ms |
33ms |
| others: | 192ms |
| total: | 407ms |
