Обновление lambda
Нужно ли после сохранения кода Лямбды в консоли AWS выполнить Action - > "Publish new vertion" Publish new version from $LATEST Publishing a new version saves a snapshot of the code and configuration of the $LATEST version. You can't edit the new version's code. Click to confirm ... |
| 17.04.2019, 15:38 |
start [/forum/topic.php?fid=48&gotonew=1&tid=1856590]: |
53ms |
54ms |
| others: | 244ms |
| total: | 416ms |
