шатдаун MySQL
как зашатдаунить MySQL с помощью SQL-запроса? ... |
| 09.12.2002, 01:55:28 |
шатдаун MySQL
Я что-то ничего не нашел! Можно попробовать так или запустить mysqladmin shutdown SHOW PROCESSLIST shows you which threads are running. You can also get this information using the mysqladmin processlist command. If you have the process privilege, you can see all threads. Otherwise, you can see only your own threads. See section 4.5.4 KILL Syntax. If you don't use the FULL option, then only the first 100 characters of each query will be shown. This command is very useful if you get the 'too many connections' error message and want to find out what's going on. MySQL reserves one extra connection for a client with the Process_priv privilege to ensure that you should always be able to login and check the system (assuming you are not giving this privilege to all your users). ... |
| 09.12.2002, 10:12:40 |
шатдаун MySQL
просто в том же Ms SQL есть такая возможность - в SQL-запросе пишешь SHUTDOWN WITH NOWAIT и если права позволяют... ... |
| 09.12.2002, 16:34:50 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1856232]: |
30ms |
46ms |
| others: | 200ms |
| total: | 315ms |
