Есть ли stored procidures в MySQL ?
Не подскажите, есть ли stored procidures в MySQL, если да - подскажите где про это можно почитать? Заранее спасибо ... |
| 16.05.2003, 20:17:26 |
from www.mysql.com: ========= The MySQL database server will provide hooks for implementing stored procedures in multiple languages, as well as including support for the Persistent Stored Modules syntax defined as part of ANSI SQL-99. Support for stored procedures and triggers will be introduced in version 5.0. ============== JJ ... |
| 16.05.2003, 21:00:48 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1856018]: |
50ms |
36ms |
| others: | 199ms |
| total: | 322ms |
