трабл с настройкой innodb таблиц
помогите, пожалуйста кто сможет... при включении в my.cnf строки innodb_data_file_path = ibdata1:16M:autoextend;ibdata2:16M:autoextend сервер отказывается запускаться, в чём дело??? ... |
| 16.05.2003, 10:42:26 |
А что в логах говорится? ... |
| 16.05.2003, 11:09:47 |
в логах пишет следующее: "030516 12:15:07 InnoDB: syntax error in innodb_data_file_path 030516 12:15:07 Can't init databases MySql: ready for connections Cannot initialize InnoDB as 'innodb_data_file_path' is not set. If you do not want to use transactional InnoDB tables, add a line skip-innodb to the [mysqld] section of init parameters in your my.cnf or my.ini. If you want to use InnoDB tables, add to the [mysqld] section, for example, innodb_data_file_path = ibdata1:10M:autoextend But to get good performance you should adjust for your hardware the InnoDB startup options listed in section 2 at http://www.innodb.com/ibman.html 030516 15:50:44 MySql: Normal shutdown" при закомментированном параметре, а если его раскомментировать, то пишет следующее: "030516 10:33:10 InnoDB: Operating system error number 123 in a file operation. InnoDB: See http://www.innodb.com/ibman.html for installation help. InnoDB: Look from section 13.2 at http://www.innodb.com/ibman.html InnoDB: what the error number means. InnoDB: File name c: usphere\mysql\data\innodb\ibdata2 InnoDB: Cannot continue operation. 030516 10:37:35 InnoDB: syntax error in innodb_data_file_path 030516 10:37:35 Can't init databases 030516 10:37:40 InnoDB: syntax error in innodb_data_file_path 030516 10:37:40 Can't init databases 030516 10:38:05 InnoDB: syntax error in innodb_data_file_path 030516 10:38:05 Can't init databases 030516 10:38:21 InnoDB: Operating system error number 123 in a file operation. InnoDB: See http://www.innodb.com/ibman.html for installation help. InnoDB: Look from section 13.2 at http://www.innodb.com/ibman.html InnoDB: what the error number means. InnoDB: File name c: usphere\mysql\data\innodb\ibdata2 InnoDB: Cannot continue operation. 030516 10:38:43 InnoDB: Operating system error number 123 in a file operation. InnoDB: See http://www.innodb.com/ibman.html for installation help. InnoDB: Look from section 13.2 at http://www.innodb.com/ibman.html InnoDB: what the error number means. InnoDB: File name c: usphere\mysql\data\innodb\ibdata2 InnoDB: Cannot continue operation. MySql: ready for connections Cannot initialize InnoDB as 'innodb_data_file_path' is not set. If you do not want to use transactional InnoDB tables, add a line skip-innodb to the [mysqld] section of init parameters in your my.cnf or my.ini. If you want to use InnoDB tables, add to the [mysqld] section, for example, innodb_data_file_path = ibdata1:10M:autoextend But to get good performance you should adjust for your hardware the InnoDB startup options listed in section 2 at http://www.innodb.com/ibman.html 030516 12:15:06 MySql: Normal shutdown" вот примерно так... ... |
| 19.05.2003, 08:32:30 |
Пути должны быть укащзаны в подобном формате: Код: plaintext 1. 2. 3. 4. 5. 6. ... |
| 19.05.2003, 10:25:32 |
| 19.05.2003, 10:39:52 |
не помогает, пробовал... ... |
| 19.05.2003, 15:34:44 |
Вот примерно такой кусок должен быть у тебя в my.cnf: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. ... |
| 19.05.2003, 16:00:53 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1856011]: |
52ms |
46ms |
| others: | 206ms |
| total: | 348ms |
