Ошибка при сборке
Привет всем Не ставил ли кто MySQL под Solaris 8? Configure проходит нормально, а make вываливается на вот такой ошибке (концовка): g++ -DMYSQL_SERVER -DDEFAULT_MYSQL_HOME="\"/usr/local/mysql\"" -DDATADIR="\"/usr/local/mysql/var\"" -DSHAREDIR="\"/usr/local/mysql/share/mysql\"" -DHAVE_CONFIG_H -I. -I. -I.. -I../innobase/include -I./../include -I./../regex -I. -I../include -I. -O3 -DDBUG_OFF -fno-implicit-templates -fno-exceptions -fno-rtti -D_FILE_OFFSET_BITS=64 -DHAVE_CURSES_H -I/usr/local/mysql-4.0.13/include -DHAVE_RWLOCK_T -c -o sql_lex.o `test -f sql_lex.cc || echo './'`sql_lex.cc sql_lex.cc: In function `void lex_init()': sql_lex.cc:85: error: `symbols' undeclared (first use this function) sql_lex.cc:85: error: (Each undeclared identifier is reported only once for each function it appears in.) sql_lex.cc:87: error: `sql_functions' undeclared (first use this function) sql_lex.cc: In function `int find_keyword(LEX*, unsigned int, bool)': sql_lex.cc:171: error: `get_hash_symbol' undeclared (first use this function) make: *** [sql_lex.o] Error 1 make: Leaving directory `/usr/local/mysql-4.0.13/sql' make: *** [all-recursive] Error 1 make: Leaving directory `/usr/local/mysql-4.0.13/sql' make: *** [all] Error 2 make: Leaving directory `/usr/local/mysql-4.0.13/sql' make: *** [all-recursive] Error 1 make: Leaving directory `/usr/local/mysql-4.0.13' make: *** [all] Error 2 # Никто не сталкивался? ... |
| 05.06.2003, 15:14:00 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1855958]: |
52ms |
25ms |
| others: | 203ms |
| total: | 324ms |
