КАК ДОБАВИТЬ ДАННЫЕ?
ЕСТЬ ТАКАЯ ФОРМА: #!/usr/bin/perl use CGI ; use strict; print "Content-Type:text/html;win-1251\n\n"; print "<html><body bgcolor='lightblue' text='black' link='green' vlink='magenta'><h2>test</h2><hr>\n"; print "<pre>"; print "<b>Заполните пожалуйста предложенную форму и введенные Вами данные будут добавлены в таблицу </b>"; print "<form Method=Post Action=/cgi/add.pl>"; print "<pre>"; print " <b> NPP </b> <input type=text name=npps value='' maxlength=3 size=2>"; print "<b> NUMBER </b><input type=text name=numbers value='' maxlength=7 size=7>"; print" <b> FILM </b><input type=text name=films value='' maxlength=30 size=10>"; print"<b> AUTORS </b><input type=text name=autorss value='' maxlength=20 size=10>"; print "\n"; print "\n"; print "\n"; print"<b>TIMECODE</b><input type=text name=timecodes value='' maxlength=6 size=6>"; print"<b> ANNOTATION </b><input type=text name=annotations value='' maxlength=50 size=10>"; print "\n"; print "\n"; print "\n"; print"<b>DATA DATA DATA"; print "\n"; print"RELEASE OCENKI END</b>"; print "\n"; print"<input type=text name=date_of_recordss value='' maxlength=10 size=10>"; print"<b> </b><input type=text name=data_ocenkis value='' maxlength=10 size=10><b> "; print" </b><input type=text name=data_ends value='' maxlength=10 size=10>"; print "\n"; print "\n"; print "\n"; print"<b> </b> <input type=submit value='INSERT RECORD'></pre> "; print "</body></html>\n"; И ТАКОЙ СКРИПТ: #!/usr/bin/perl use CGI ; $query = new CGI; print "Content-Type:text/html;win-1251\n\n"; print "<html><body bgcolor='lightblue' text='black' link='green' vlink='magenta'><h2>test</h2><hr>\n"; use dbi; use Mysql; $dbh = Mysql->connect($localhost, $ddd, $root); $dbh->selectdb("ddd"); $np = $query->param("npps"); $numb = $query->param("numbers"); $fil = $query->param("films"); $autor = $query->param("autorss"); $time = $query->param("timecodes"); $annot = $query->param("annotations"); $data_rel = $query->param("date_of_recordss"); $data_ocen = $query->param("data_ocenkis"); $data_en = $query->param("data_ends"); $sth = $dbh->query ("insert into records(npp) values ($np)"); $sth = $dbh->query ("insert into records(number) values ($numb)"); $sth = $dbh->query ("insert into records(film) values ('$fil')"); $sth = $dbh->query ("insert into records(autors) values ('$autor')"); $sth = $dbh->query ("insert into records(time_code) values ($time)"); $sth = $dbh->query ("insert into records(annotation) values ('$annot')"); $sth = $dbh->query ("insert into records(data_ocenki) values ($data_ocen)"); $sth = $dbh->query ("insert into records(date_of_rec) values ($data_rel)"); $sth = $dbh->query ("insert into records(data_end) values ($data_en)"); print "<a href='http://localhost/'>в начало</a>"; print "</body></html>\n"; ВОПРОС: ПОЧЕМУ В БАЗУ ДАННЫХ ВНОСИТСЯ ТОЛЬКО СТРОКА FILM? ... |
| 06.06.2003, 00:29:56 |
А вы уверены, что заполняется только строка film? Похоже, должны еще заполниться autors и annotation. Я, правда, синтаксиса Перла не знаю, но обратила внимание на наличие или отсутствие апострофов при заполнении полей. Может, в этом проблема? ... |
| 06.06.2003, 10:05:21 |
А почему не так: Код: plaintext 1. 2. 3. 4. 5. 6. С одной стороны все значения полей надо обрамлять апострофом, ноиногда сервер может ругаться когда значение INT обрамлено апострофом... Одним словом пробуй-смотри на результат! ... |
| 06.06.2003, 13:34:35 |
надо полагать таблица содержит поле типа char или varchar. Поэтому когда вы вставляете film - все в порядке. Когда вы в это поле вставляете число ( точнее - не строку, без апострофов) - mysql возвращает ощибку. Но вы то в скрипте ответ сервера не проверяете (почемуто). ... |
| 23.06.2003, 02:17:54 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1855954]: |
72ms |
37ms |
| others: | 234ms |
| total: | 384ms |
