ошибка при connection к mySQL из java
привет всем! вот кусок кода. питаюсь законектиться к mySQL из Java. public ResultSet result_query() { JDBC_DRIVER = "com.mysql.jdbc.Driver"; DATABASE_URL = "jdbc:odbc:catalog_content"; USERNAME = "root"; PASSWORD = ""; SUB_DIR_QUERY = "SELECT * FROM `subdirectory` where id = 1"; try { Class.forName(JDBC_DRIVER).newInstance(); Connection con_directory = DriverManager.getConnection(DATABASE_URL,USERNAME,PASSWORD); Statement stmt_directory = con_directory.createStatement() qres = stmt_directory.executeQuery(SUB_DIR_QUERY); } catch (Exception E) { E.printStackTrace(); } return qres; } //================================================================================================ видает ошибку: java.sql.SQLException: No suitable driver at java.sql.DriverManager.getConnection(DriverManager.java:532) at java.sql.DriverManager.getConnection(DriverManager.java:171) at catalog.DB_MANAGE.result_query(DB_MANAGE.java:31) at catalog.DB_MANAGE.main(DB_MANAGE.java:45) java.lang.NullPointerException at catalog.DB_MANAGE.main(DB_MANAGE.java:50) что делать не знаю. дривер скачен с саита mySQL.com . прописани его папки com , org в project. заранее спасибо. ... |
| 03.09.2003, 19:47:07 |
Навскидку - драйвер цепляешь: mysql а коннектишся к другому драйверу - к odbc. jdbc: odbc :catalog_content ... |
| 03.09.2003, 22:58:37 |
исправил: public ResultSet result_query() { JDBC_DRIVER = "com.mysql.jdbc.Driver"; //DATABASE_URL = "jdbc:odbc:catalog_content"; //JDBC_DRIVER = "org.gjt.mm.mysql.Driver"; DB_NAME = "catalog_content"; //DB_NAME = "test"; USERNAME = "root"; PASSWORD = ""; SUB_DIR_QUERY = "SELECT * FROM `subdirectory` where id = 1"; try { Class.forName(JDBC_DRIVER).newInstance(); java.sql.Connection con_directory = DriverManager.getConnection("jdbc:mysql://localhost"+DB_NAME,"root",""); Statement stmt_directory = con_directory.createStatement();//stmt=conn.prepareStatement ("SELECT * FROM conf_links"); qres = stmt_directory.executeQuery(SUB_DIR_QUERY); } catch (Exception E) { E.printStackTrace(); } return qres; } //=================================================== результат , таже ошибка: java.sql.SQLException: No suitable driver at java.sql.DriverManager.getConnection(DriverManager.java:532) at java.sql.DriverManager.getConnection(DriverManager.java:171) at catalog.DB_MANAGE.result_query(DB_MANAGE.java:35) at catalog.DB_MANAGE.main(DB_MANAGE.java:56) java.lang.NullPointerException at catalog.DB_MANAGE.main(DB_MANAGE.java:62) как бить? ... |
| 04.09.2003, 02:18:44 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1855810]: |
119ms |
31ms |
| others: | 206ms |
| total: | 387ms |
