PHP JAVA SCRIPT MY SQL
Problema s pereda4ej porametrov iz Java script v PHP i zapisivanijem etogo v bazu mysql vse po otdelnosti rabotaet, no r[1] r[2] on ne vosprinemajet ka parametri iz Java script! Pomogite plz! <SCRIPT language=JavaScript> <!--// r= new Array(100); r[0]=0;r[1]=0;r[2]=0;r[3]=0;r[4]=0;r[5]=0;r[6]=0;r[7]=0;r[8]=0; function qp() {kp=0;j=0;i=0; for(j=0;j<4;j++){ {k=0; i=j*4; if(j>2){i=(j*4)-2;} while((k<12)&&(!document.q.elements .checked)) {i++;k++;} r[j]=(k+1); } } r[6]=' ПРАВИЛЬНО?' window.alert("Спасибо "+r[0]+r[1]+r[2]+r[3]+r[6]); <? // database connection mysql_connect("127.0.0.1","root",""); // database selection mysql_select_db("anketa"); mysql_query("insert into anketa values($r[1],'1','1','1','4','4','4')"); // kak tut pisatj?? ?> } //--> </SCRIPT> ... |
| 29.10.2003, 13:35:18 |
start [/forum/search_topic.php?author=GLUKAS&author_mode=last_topics&do_search=1]: |
46ms |
34ms |
| others: | 637ms |
| total: | 794ms |
