помогите найти ошибку
Ошибка SQL-запрос : SELECT tbl_bonus_users.t_user_id, tbl_bonus_works.t_work_description FROM tbl_bonus_users, tbl_bonus_works WHERE tbl_bonus_users.t_user_id = "dens" AND tbl_bonus_users.t_user_id IN ( SELECT tbl_bonus_check_access.t_group_rule_id FROM tbl_bonus_check_access WHERE tbl_bonus_check_access.t_inspector_id = tbl_bonus_users.t_user_id ) AND tbl_bonus_users.t_user_id = tbl_bonus_users.t_user_id LIMIT 0, 30 Ответ MySQL: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'SELECT tbl_bonus_check_access.t_group_rule_id FROM tbl_bonus_ch ... |
| 01.12.2003, 18:07:59 |
пробовал и так Ошибка SQL-запрос : SELECT b.t_user_id, d.t_work_description FROM tbl_bonus_users AS a, tbl_bonus_users AS b, tbl_bonus_works AS d WHERE a.t_user_id = "dens" AND b.t_user_id IN ( SELECT c.t_group_rule_id FROM tbl_bonus_check_access AS c WHERE c.t_inspector_id = a.t_user_id ) AND b.t_user_id = d.t_user_id LIMIT 0, 30 Ответ MySQL: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'SELECT c.t_group_rule_id FROM tbl_bonus_check_access AS c WHERE Назад ... |
| 01.12.2003, 18:09:31 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1855595]: |
45ms |
| others: | 205ms |
| total: | 304ms |
