Как увеличить лимит на кол-во таблиц участвующих в запросе
Сабж. Заранее спасибо. ... |
| 12.01.2004, 12:30:43 |
А такой существует? mahoune ... |
| 12.01.2004, 13:54:51 |
Конечно, при применении такого запроса select a.adres, p1.data, p1.pokaz, p2.data, p2.pokaz, p3.data, p3.pokaz, p4.data, p4.pokaz, p5.data, p5.pokaz, p6.data, p6.pokaz, p7.data, p7.pokaz, p8.data, p8.pokaz, p9.data, p9.pokaz, p10.data, p10.pokaz, p11.data, p11.pokaz, p12.data, p12.pokaz, p13.data, p13.pokaz, p14.data, p14.pokaz, p15.data, p15.pokaz, p16.data, p16.pokaz, p17.data, p17.pokaz, p18.data, p18.pokaz, p19.data, p19.pokaz, p20.data, p20.pokaz, p21.data, p21.pokaz, p22.data, p22.pokaz, p23.data, p23.pokaz, p24.data, p24.pokaz, p25.data, p25.pokaz, p26.data, p26.pokaz, p27.data, p27.pokaz, p28.data, p28.pokaz, p29.data, p29.pokaz, p30.data, p30.pokaz from probabon as p1 left join adresprobabon as a on a.uniq=p1.touniq left join probabon as p2 on p2.touniq=p1.touniq and date_format(p2.data, '%d')=2 left join probabon as p3 on p3.touniq=p1.touniq and date_format(p3.data, '%d')=3 left join probabon as p4 on p4.touniq=p1.touniq and date_format(p4.data, '%d')=4 left join probabon as p5 on p5.touniq=p1.touniq and date_format(p5.data, '%d')=5 left join probabon as p6 on p6.touniq=p1.touniq and date_format(p6.data, '%d')=6 left join probabon as p7 on p7.touniq=p1.touniq and date_format(p7.data, '%d')=7 left join probabon as p8 on p8.touniq=p1.touniq and date_format(p8.data, '%d')=8 left join probabon as p9 on p9.touniq=p1.touniq and date_format(p9.data, '%d')=9 left join probabon as p10 on p10.touniq=p1.touniq and date_format(p10.data, '%d')=10 left join probabon as p11 on p11.touniq=p1.touniq and date_format(p11.data, '%d')=11 left join probabon as p12 on p12.touniq=p1.touniq and date_format(p12.data, '%d')=12 left join probabon as p13 on p13.touniq=p1.touniq and date_format(p2.data, '%d')=13 left join probabon as p14 on p14.touniq=p1.touniq and date_format(p3.data, '%d')=14 left join probabon as p15 on p15.touniq=p1.touniq and date_format(p4.data, '%d')=15 left join probabon as p16 on p16.touniq=p1.touniq and date_format(p5.data, '%d')=16 left join probabon as p17 on p17.touniq=p1.touniq and date_format(p6.data, '%d')=17 left join probabon as p18 on p18.touniq=p1.touniq and date_format(p7.data, '%d')=18 left join probabon as p19 on p19.touniq=p1.touniq and date_format(p8.data, '%d')=19 left join probabon as p20 on p20.touniq=p1.touniq and date_format(p9.data, '%d')=20 left join probabon as p21 on p21.touniq=p1.touniq and date_format(p10.data, '%d')=21 left join probabon as p22 on p22.touniq=p1.touniq and date_format(p11.data, '%d')=22 left join probabon as p23 on p23.touniq=p1.touniq and date_format(p12.data, '%d')=23 left join probabon as p24 on p24.touniq=p1.touniq and date_format(p10.data, '%d')=24 left join probabon as p25 on p25.touniq=p1.touniq and date_format(p11.data, '%d')=25 left join probabon as p26 on p26.touniq=p1.touniq and date_format(p12.data, '%d')=26 left join probabon as p27 on p27.touniq=p1.touniq and date_format(p10.data, '%d')=27 left join probabon as p28 on p28.touniq=p1.touniq and date_format(p11.data, '%d')=28 left join probabon as p29 on p29.touniq=p1.touniq and date_format(p12.data, '%d')=29 left join probabon as p30 on p30.touniq=p1.touniq and date_format(p10.data, '%d')=30 where date_format(p1.data, '%d')=1 работает, если же добавляю еще одну таблицу в запрос, выдает что превышен предел в 31 таблицу. ... |
| 12.01.2004, 14:07:48 |
Может переменная max_tmp_tables поможет? А вообще текст ошибки какой? Может ему памяти не хватает? mahoune ... |
| 12.01.2004, 14:37:47 |
А как эту переменную изменить? :( Если можно, то проще, а то я кроме select больше ничего не умею :( ... |
| 12.01.2004, 15:04:58 |
запрос такой лучше бы переписать по другому, или таблицу с днями в столбцах делать в клиенте. опишите задачу, может это надо не так делать совсем. упирание в такой лимит свидетельствует о неправильной разработке программы имхо ... |
| 12.01.2004, 15:11:25 |
Есть таблица с тремя полями название, дата, показания на эту дату. Необходимо средствами sql выдать информацию по названиям какие показания есть на определенную дату (информация месячная - значит должно быть 31 колонка показаний, 31 колонка дат (не обязательно) одна колонка наименования. ... |
| 12.01.2004, 15:23:06 |
насчет того как изменить переменную - разобрался... ... |
| 12.01.2004, 15:28:46 |
выдает ошибку SQL error: Too many tables. MySQL can only use 31 tables in a join. ... |
| 12.01.2004, 15:33:51 |
А вообще fedd прав. Может тебе просто при выводе лучше формировать "колонки" а результат получать в строчках? mahoune ... |
| 12.01.2004, 15:34:07 |
точно только средствами sql? пользователь будет в шеле смотреть результат? //насколько я знаю, cross-tab запросы есть только в Аксессе, это нестандартно. ... |
| 12.01.2004, 15:34:28 |
Понимаете, там уже разработано универсальное отчетное приложение. У которого есть только DBGRID и набор sql запросов, которые приложение запускает, обрабатывает и показывает в grid. То есть это не самостоятельный запрос, к сожалению :( ... |
| 12.01.2004, 15:41:31 |
тогда не знаю что делать :( ... |
| 12.01.2004, 15:56:17 |
Какой ужас.. Тогда бы я посоветовал вам создать временную таблицу с 32 колонками, залить туда по очереди все таблицы (в соответствующие колонки), а уж потом отдавать эту временку на растерзание для dbgrid-у но вообще конечно, такие запросы и такие условия задачи - это ошибки проектирования Вашего "универсального" отчетника. ... |
| 12.01.2004, 20:55:24 |
2Хрен Я в общем то так и решил... Но все равно спасибо :) ... |
| 16.01.2004, 14:18:57 |
все привет так что, никто не придумал как указать mysql чтобы в запросе можно было применять больше обьединений (join) ? Заранее спасибо ... |
| 25.06.2004, 15:20:43 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1855031]: |
37ms |
36ms |
| others: | 189ms |
| total: | 302ms |
