Big Query
I have big query with a problem inside.Probably you can help me to find an fix this problem.it doesn't run.This is my query: select front.*, image_data.Type, image_data.ContentType, image_data.GUID, image_data.Size, image_data.Width, image_data.Height from image_info as front inner join image_data on front.image_id = image_data.image_info_id where front.Image_ID in (select front.image_id from image_info as front inner join image_data on front.image_id = image_data.image_info_id where (front.Title like '%a%' OR front.Description like '%a%' OR front.Place like '%a%' ) AND image_data.type = 2 AND front.IsReverse = 0 union select reverse.image_id from image_info as front left outer join image_info as reverse on front.Reverse_Image_ID = reverse.Image_ID left outer join image_data on reverse.Image_ID = image_data.image_info_id where (front.Title like '%a%' OR front.Description like '%a%' OR front.Place like '%a%' ) AND image_data.type = 2 AND front.IsReverse = 0)) union select reverse.*, image_data.Type, image_data.ContentType, image_data.GUID, image_data.Size, image_data.Width, image_data.Height from image_info as front left outer join image_info as reverse on front.Reverse_Image_ID = reverse.Image_ID left outer join image_data on reverse.Image_ID = image_data.image_info_id where front.Image_ID in (select front.image_id from image_info as front inner join image_data on front.image_id = image_data.image_info_id where (front.Title like '%a%' OR front.Description like '%a%' OR front.Place like '%a%' ) AND image_data.type = 2 AND front.IsReverse = 0 union select reverse.image_id from image_info as front left outer join image_info as reverse on front.Reverse_Image_ID = reverse.Image_ID left outer join image_data on reverse.Image_ID = image_data.image_info_id where (front.Title like '%a%' OR front.Description like '%a%' OR front.Place like '%a%' ) AND image_data.type = 2 AND front.IsReverse = 0)); My regards!!! ... |
| 19.07.2004, 10:09:56 |
Big Query
Versiya : 5.0.0-alpha-max-debug ... |
| 19.07.2004, 10:46:19 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1854970]: |
64ms |
26ms |
| others: | 219ms |
| total: | 350ms |
