Установка MySQL 4.0.12 на FreeBSD 5.2
делаю ./configure --prefix=/usr/local/mysql --localstatedir=/usr/local/mysql/data --with-mysqld-user=mysql --disable-large-files --without-debug --with-charset=cp1251 --with-extra-charsets=all --without-docs потом make в результате ......... Making all in libmysql source='libmysql.c' object='libmysql.lo' libtool=yes depfile='.deps/libmysql.Plo' tmpdepfile='.deps/libmysql.TPlo' depmode=gcc3 /bin/sh ../depcomp /bin/sh ../libtool --mode=compile gcc -DDEFAULT_CHARSET_HOME="\"/usr/local/mysql\"" -DDATADIR="\"/usr/local/mysql/var\"" -DSHAREDIR="\"/usr/local/mysql/share/mysql\"" -DUNDEF_THREADS_HACK -DDONT_USE_RAID -DMYSQL_CLIENT -I. -I. -I.. -I./../include -I../include -I./.. -I.. -I.. -O3 -DDBUG_OFF -DHAVE_BROKEN_REALPATH -c -o libmysql.lo `test -f libmysql.c || echo './'`libmysql.c : not found ../libtool: 317: Syntax error: "elif" unexpected (expecting "then") *** Error code 2 Stop in /usr/home/bg4/dist/mysql-4.0.12/libmysql. *** Error code 1 Stop in /usr/home/bg4/dist/mysql-4.0.12. *** Error code 1 Stop in /usr/home/bg4/dist/mysql-4.0.12. Как побороть? ... |
| 27.10.2004, 21:21:49 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1854646]: |
38ms |
25ms |
| others: | 247ms |
| total: | 345ms |
