проблемы с FULLTEXT
Здравствуйте, люди!!! У меня вопрос... Читал мануал про фултекст, там пример есть, типа: mysql> CREATE TABLE articles ( id INT UNSIGNED AUTO_INCREMENT NOT NULL PRIMARY KEY, title VARCHAR(200), body TEXT, FULLTEXT (title,body) ); Query OK, 0 rows affected (0.00 sec) mysql> INSERT INTO articles VALUES -> (NULL,'MySQL Tutorial', 'DBMS stands for DataBase ...'), -> (NULL,'How To Use MySQL Efficiently', 'After you went through a ...'), -> (NULL,'Optimising MySQL','In this tutorial we will show ...'), -> (NULL,'1001 MySQL Tricks','1. Never run mysqld as root. 2. ...'), -> (NULL,'MySQL vs. YourSQL', 'In the following database comparison ...'), -> (NULL,'MySQL Security', 'When configured properly, MySQL ...'); Query OK, 6 rows affected (0.00 sec) Records: 6 Duplicates: 0 Warnings: 0 mysql> SELECT * FROM articles WHERE MATCH (title,body) AGAINST ('database'); +----+-------------------+------------------------------------------+ | id | title | body | +----+-------------------+------------------------------------------+ | 5 | MySQL vs. YourSQL | In the following database comparison ... | | 1 | MySQL Tutorial | DBMS stands for DataBase ... | +----+-------------------+------------------------------------------+ 2 rows in set (0.00 sec) проблема вот в чём... как так может быть??? создаю таблицу: create table ind (id int not null auto_increment, zap smallint(1) DEFAULT 1, url varchar(40), nazv varchar(250), d_ind DATE, pop double(8,5) DEFAULT 0, tit double(8,5) DEFAULT 0, ob double(6,5) DEFAULT 1, atit double(8,5) DEFAULT 0, des double(8,5) DEFAULT 0, kw double(8,5) DEFAULT 0, n_rubr varchar(70), opis TEXT, inde TEXT, FULLTEXT (url, nazv, opis, inde), primary key (id)) далее запрос на поиск: SELECT url, nazv from ind where MATCH(url,nazv,inde) AGAINST('sddfsgdfg') и Ошибка!!! типа: Can't find FULLTEXT index matching the column list как так??? ... |
| 07.12.2004, 10:47:13 |
проблемы с FULLTEXT
Код: plaintext А так работает? Жизнь коротка - потерпи немного :) ... |
| 07.12.2004, 12:52:44 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1854555]: |
36ms |
| others: | 195ms |
| total: | 286ms |
