Ошибки компиляции под gcc - Lib'ы для MySQL'я?
Есть сложнейшая программа test.c : #include </usr/include/stdlib.h> #include </usr/include/stdio.h> #include </usr/local/include/sql.h> #include </usr/local/include/sqlext.h> #include </usr/local/include/sqltypes.h> SQLHDBC SQL_Connection_Handle; int main (int argc, char *argv[]) { SQLDisconnect(SQL_Connection_Handle); exit(0); } При компиляции GCC 3.2.2 под FreeBSD 5.1 выдает ошибку: gcc -o test test.c /var/tmp//cc4aTTuZ.o: In function `main': /var/tmp//cc4aTTuZ.o(.text+0x219): undefined reference to `SQLDisconnect' GCC не может найти библиотек? Их навалом - шедшая с дистрибутивом МуСКУля, МуОДБЦ, ЮниксОДБС, Иодбц. Согласно "/sbin/ldconfig -r" библиотеки есть : /sbin/ldconfig -r | grep odbc 268:-liodbc.3 => /usr/local/lib/libiodbc.so.3 269:-liodbcadm.3 => /usr/local/lib/libiodbcadm.so.3 270:-liodbcinst.3 => /usr/local/lib/libiodbcinst.so.3 276:-lodbc.1 => /usr/local/lib/libodbc.so.1 277:-lodbccr.1 => /usr/local/lib/libodbccr.so.1 278:-lodbcdrvcfg1S.1 => /usr/local/lib/libodbcdrvcfg1S.so.1 279:-lodbcdrvcfg2S.1 => /usr/local/lib/libodbcdrvcfg2S.so.1 280:-lodbcextras.1 => /usr/local/lib/libodbcextras.so.1 281:-lodbcinst.1 => /usr/local/lib/libodbcinst.so.1 282:-lodbcminiS.1 => /usr/local/lib/libodbcminiS.so.1 283:-lodbcmyS.1 => /usr/local/lib/libodbcmyS.so.1 284:-lodbcnnS.1 => /usr/local/lib/libodbcnnS.so.1 285:-lodbcpsql.1 => /usr/local/lib/libodbcpsql.so.1 286:-lodbcpsql.2 => /usr/local/lib/libodbcpsql.so.2 287:-lodbcpsqlS.1 => /usr/local/lib/libodbcpsqlS.so.1 288:-lodbctxt.1 => /usr/local/lib/libodbctxt.so.1 289:-lodbctxtS.1 => /usr/local/lib/libodbctxtS.so.1 290:-loplodbcS.1 => /usr/local/lib/liboplodbcS.so.1 291:-loraodbcS.1 => /usr/local/lib/liboraodbcS.so.1 /sbin/ldconfig -r | grep sql search directories: /usr/lib:/usr/lib/compat:/usr/X11R6/lib:/usr/local/lib:/usr/local/lib/mysql:/usr/local/lib/kde3 271:-lsqlplus.1 => /usr/local/lib/libsqlplus.so.1 285:-lodbcpsql.1 => /usr/local/lib/libodbcpsql.so.1 286:-lodbcpsql.2 => /usr/local/lib/libodbcpsql.so.2 287:-lodbcpsqlS.1 => /usr/local/lib/libodbcpsqlS.so.1 296:-lmysqlclient.12 => /usr/local/lib/mysql/libmysqlclient.so.12 297:-lmysqlclient_r.12 => /usr/local/lib/mysql/libmysqlclient_r.so.12 298:-lmysqlclient.14 => /usr/local/lib/mysql/libmysqlclient.so.14 299:-lmysqlclient_r.14 => /usr/local/lib/mysql/libmysqlclient_r.so.14 300:-lmysqlclient.10 => /usr/local/lib/mysql/libmysqlclient.so.10 Пробую указать GCC необходимость подключения библиотек, но всякие варианты отвергаются : gcc -l odbc -o test test.c /usr/bin/ld: cannot find -lodbc ЮниксОДБЦ, например, ставился так : fetch http://www.unixodbc.org/unixODBC-2.2.10.tar.gz tar zxf unixODBC-2.2.10.tar.gz cd unixODBC-2.2.10 ./configure --prefix=/usr/local --exec-prefix=/usr/local --includedir=/usr/local/include --enable-gui=no make make install ls /usr/local/include | grep odbc odbcinst.h odbcinstext.h uodbc_stats.h cd .. fetch http://www.unixodbc.org/unixODBC-2.2.10.tar.gz tar zxf unixODBC-2.2.10.tar.gz cd unixODBC-2.2.10 ./configure --prefix=/usr/local --exec-prefix=/usr/local --includedir=/usr/local/include --enable-gui=no make make install ls /usr/local/include | grep odbc odbcinst.h odbcinstext.h uodbc_stats.h cd .. /sbin/ldconfig -R /sbin/ldconfig -r Пробовал откомпилировать 'clients' из дистрибутива МуСКУля - куча ошибок. Может зря я связался с ОДБЦ, мне нужно на Ц без плюсов написать простую прогу для МуСКУля. Читал http://dev.mysql.com/doc/mysql/ru/C.html вроде проще и быстрее должно работать, но таже проблема с библиотеками. Поделитесь упрощенным прототипом и скажите как библиотеки цеплять, чтобы ГЦЦ компилил. ... |
| 02.01.2005, 18:56:33 |
в дистрибутиве mysql должен быть mysql_config Запускаешь его mysql_config --libs и он тебе пишет бибки которые надо прицепить. mysql_config --cflags и он пишет ключи для mysql которые нужны при трансляции но это только относится конечно к чистому mysql клиенту без odbc ... |
| 03.01.2005, 12:51:30 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1854464]: |
3520ms |
28ms |
| others: | 224ms |
| total: | 3815ms |
