java.sql.SQLException ?
java.sql.SQLException: [MySQL][ODBC 3.51 Driver][mysqld-5.0.16-nt]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'job.materialid=material.id' at line 1 не понятно почему возникает ислючение Код: plaintext 1. 2. 3. ... |
| 23.11.2005, 13:39:34 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1853412]: |
74ms |
30ms |
| others: | 222ms |
| total: | 372ms |
