ошибка при работе с MySQL Migration Toolkit
Подскажите пожалуйста, в чес может быть ошибка при попытке соединения с target-БД? -------------------------------------------------------------------------------- Connection jdbc:mysql://127.0.0.1:3306/?user=root&password=sp3+98&useServerPrepStmts=false The connection to the target database could not be established (error: 0). ReverseEngineeringMysqlJdbc.getVersion :Access denied for user 'root'@'localhost' (using password: YES) Details: com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2926) com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:771) com.mysql.jdbc.MysqlIO.secureAuth411(MysqlIO.java:3647) com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1176) com.mysql.jdbc.Connection.createNewIO(Connection.java:2544) com.mysql.jdbc.Connection.<init>(Connection.java:1474) com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:266) java.sql.DriverManager.getConnection(Unknown Source) java.sql.DriverManager.getConnection(Unknown Source) com.mysql.grt.modules.ReverseEngineeringGeneric.establishConnection(Unknown Source) com.mysql.grt.modules.ReverseEngineeringGeneric.getVersion(Unknown Source) sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) java.lang.reflect.Method.invoke(Unknown Source) com.mysql.grt.Grt.callModuleFunction(Unknown Source) ... |
| 12.12.2005, 13:55:35 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1853301]: |
156ms |
25ms |
| others: | 184ms |
| total: | 396ms |
