удаление выборки
DELETE FROM a, b WHERE (b.gorodzone!=5 or b.gorodzone!=3) AND b.gorodid= a.gorod не хочет удалять пишет You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE (gorodzone!=5 or gorodzone!=3) AND gorodid= gorod' at lin В чем проблема ? ... |
| 30.12.2005, 01:01:00 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1853229]: |
342ms |
53ms |
| others: | 231ms |
| total: | 681ms |
