Запрос с объединением
Есть такая таблица: -- -- Структура таблицы `songs` -- CREATE TABLE `songs` ( `id` int(11) NOT NULL auto_increment, `author_id` int(11) NOT NULL default '0', `name` varchar(255) NOT NULL default '', `type` tinyint(4) NOT NULL default '0', `tcid` int(11) default NULL, `sndx` varchar(255) NOT NULL default '', PRIMARY KEY (`id`), KEY `author_id` (`author_id`,`type`,`tcid`), KEY `name` (`name`), KEY `sndx` (`author_id`,`sndx`,`id`) ) TYPE=MyISAM AUTO_INCREMENT=2130 ; -- -- Дамп данных таблицы `songs` -- INSERT INTO `songs` VALUES (32, 3, 'Big Gun', 1, 32, 'B250'); INSERT INTO `songs` VALUES (2053, 3, 'Big Gun', 2, 114, 'B250'); INSERT INTO `songs` VALUES (2046, 3, 'Back In Black (2)', 2, 107, 'B25142'); INSERT INTO `songs` VALUES (2047, 3, 'Back In Black (3)', 2, 108, 'B25142'); INSERT INTO `songs` VALUES (2048, 3, 'Back In Black (4)', 2, 109, 'B25142'); INSERT INTO `songs` VALUES (2049, 3, 'Back in Black', 2, 110, 'B25142'); INSERT INTO `songs` VALUES (2050, 3, 'Bad Boy Boogie', 2, 111, 'B312'); INSERT INTO `songs` VALUES (2054, 3, 'Bonny', 2, 115, 'B500'); INSERT INTO `songs` VALUES (2060, 3, 'Classic Riffs', 2, 121, 'C42612'); INSERT INTO `songs` VALUES (2063, 3, 'Dog eat dog (2)', 2, 124, 'D232'); INSERT INTO `songs` VALUES (2064, 3, 'Dog Eat Dog (3)', 2, 125, 'D232'); INSERT INTO `songs` VALUES (2065, 3, 'Dog Eat Dog', 2, 126, 'D232'); INSERT INTO `songs` VALUES (2061, 3, 'Damned', 2, 122, 'D530'); INSERT INTO `songs` VALUES (2062, 3, 'Dirty Deeds Done Dirt Cheap', 2, 123, 'D6323536321'); INSERT INTO `songs` VALUES (2066, 3, 'For Those About To Rock', 2, 127, 'F6321362'); INSERT INTO `songs` VALUES (2067, 3, 'Girls got rhythm', 2, 128, 'G6423635'); INSERT INTO `songs` VALUES (2071, 3, 'Have a drink on me (2)', 2, 132, 'H136525'); INSERT INTO `songs` VALUES (2072, 3, 'Have A Drink On Me (3)', 2, 133, 'H136525'); INSERT INTO `songs` VALUES (2073, 3, 'Have A Drink On Me', 2, 134, 'H136525'); INSERT INTO `songs` VALUES (2079, 3, 'High Voltage', 2, 140, 'H21432'); INSERT INTO `songs` VALUES (33, 3, 'Highway To Hell', 1, 33, 'H234'); INSERT INTO `songs` VALUES (2080, 3, 'Highway to Hell (2)', 2, 141, 'H234'); INSERT INTO `songs` VALUES (2081, 3, 'Highway To Hell (3)', 2, 142, 'H234'); INSERT INTO `songs` VALUES (2083, 3, 'Highway to Hell', 2, 144, 'H234'); INSERT INTO `songs` VALUES (2082, 3, 'Highway To Hell (solo)', 2, 143, 'H23424'); Здесь author_id задаёт id автора/исполнителя, type -- тип данных (табы или аккорды), tcid -- id записи этих данных, name -- название композиции. Сразу скажу, что структура данных может быть предметом обсуждения, если вы можете предложить более оптимальный вариант. Нужно сделать запрос, возвращающий следующие данные: Name | chords_id | tabs_id где chords_id или tabs_id может быть нулевым, если для данного названия есть только табы или аккорды соответственно. Я добился _почти_ этого запросом SELECT A.name AS name, IF(A.type=1,A.tcid,NULL) AS chords_id, IF(B.type=2,B.tcid,NULL) AS tabs_id FROM songs AS A LEFT JOIN songs AS B ON A.name=B.name WHERE A.author_id=3 AND B.author_id=3 AND (A.type=1 OR B.type=2) ORDER BY name, chords_id DESC, tabs_id DESC; но среди результатов получаются такие затроения: | Big Gun | 32 | 114 | | Big Gun | 32 | NULL | | Big Gun | NULL | 114 | и убрать их с помощью GROUP BY name не удаётся, т.к. группировка происходит до сортировки, и запись остаётся | Big Gun | 32 | NULL | , а не | Big Gun | 32 | 114 | Судя по ухищрениям, к которым приходится прибегать в запросе, я не оптимально выбрал структуру данных, но лучших вариантов в голову не приходит.( ... |
| 13.01.2006, 06:33:33 |
Такое решение разве Вам не подойдет ? Код: plaintext 1. 2. 3. 4. 5. 6. 7. ... |
| 13.01.2006, 10:42:38 |
Спасибо, похоже, то что надо. Пока не понял, как оно работает, правда.) Насчёт MySQL следует рассчитывать только на 4.0, к сожалению... Но оно и работает на 4.0! ... |
| 13.01.2006, 10:47:10 |
а может тупо юнионом объединить пачку селектов? имхо, гораздо быстрее работать будет ;) -- Dmitry ... |
| 13.01.2006, 18:33:00 |
Гм. Каких селектов? ... |
| 13.01.2006, 23:36:30 |
ээ, ok, пробую прочитать еще раз :) ... так там дубли, а-я-я-й :) че б не провести нормализацию - выкинуть таблатуры и аккорды в отдельные таблицы, чтобы в таблице songs были только уникальные записи (песни)? -- Dmitry ... |
| 14.01.2006, 00:37:33 |
Какую структуру данных вы предлагаете? ... |
| 14.01.2006, 00:41:18 |
если честно, я не совсем понял текущую структуру, а именно - зачем в songs лежат линки на таблатуры и аккорды? может, лучше в последние положить линки на песни, ну в классическом виде: songs: id, author_id, name, ... tabs: id, song_id, ... chords: id, song_id, ... songs.id - один-ко-многим - song_id тогда запрос будет такой: SELECT s.id, s.name, t.id, c.id FROM songs s LEFT JOIN tabs t ON s.id=t.song_id LEFT JOIN chords c ON s.id=c.song_id WHERE ... хотя для скорострельности лучше вытащить сначала список песен, а уже потом на каждый пару селектов запускать, Вам же наверное на страницу надо выводить, а не все подряд из базы? -- Dmitry ... |
| 14.01.2006, 06:02:43 |
Ага, конечно! Спасибо. Дело в том, что первоначальная, с позволения сказать "структура базы" была вообще никакая, я провёл некоторую работу, чтобы хотя бы создать общую таблицу авторов и песен, но т.к. делалось всё не с того конца, получилась такая вот странная конструкция. А я в неё упёрся и всё удивлялся, почему через LEFT JOIN запрос переписать нормально не выходит. ... |
| 14.01.2006, 08:05:29 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1853173]: |
211ms |
60ms |
| others: | 200ms |
| total: | 520ms |
