Не видит содержимого таблицы
Захожу в phpmyadmin - база данных показывается, нажимаю(ничего не выводится), нажимаю на "+" - отображаются все названия таблиц. Хотел бы восстановить, уж очень долгая работа была, что повторить нереально. вот логи - 2013-09-25 15:02:38 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). 2013-09-25 15:02:38 1072 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 2013-09-25 15:02:38 1072 [Note] Plugin 'FEDERATED' is disabled. 2013-09-25 15:02:38 1072 [Note] InnoDB: The InnoDB memory heap is disabled 2013-09-25 15:02:38 1072 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions 2013-09-25 15:02:38 1072 [Note] InnoDB: Compressed tables use zlib 1.2.3 2013-09-25 15:02:38 1072 [Note] InnoDB: Not using CPU crc32 instructions 2013-09-25 15:02:38 1072 [Note] InnoDB: Initializing buffer pool, size = 20.0M 2013-09-25 15:02:38 1072 [Note] InnoDB: Completed initialization of buffer pool 2013-09-25 15:02:38 1072 [Note] InnoDB: Setting log file .\ib_logfile101 size to 64 MB 2013-09-25 15:02:39 1072 [Note] InnoDB: Setting log file .\ib_logfile1 size to 64 MB 2013-09-25 15:02:40 1072 [Note] InnoDB: Renaming log file .\ib_logfile101 to .\ib_logfile0 2013-09-25 15:02:40 1072 [Warning] InnoDB: New log files created, LSN=1626134 2013-09-25 15:02:40 1072 [Note] InnoDB: Highest supported file format is Barracuda. 2013-09-25 15:02:41 1072 [Note] InnoDB: 128 rollback segment(s) are active. 2013-09-25 15:02:41 1072 [Note] InnoDB: Waiting for purge to start 2013-09-25 15:02:41 1072 [Note] InnoDB: 5.6.13 started; log sequence number 1626636 2013-09-25 15:02:41 1072 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306 2013-09-25 15:02:41 1072 [Note] - '127.0.0.1' resolves to '127.0.0.1'; 2013-09-25 15:02:41 1072 [Note] Server socket created on IP: '127.0.0.1'. 2013-09-25 15:02:42 1072 [Note] Event Scheduler: Loaded 0 events 2013-09-25 15:02:42 1072 [Note] C:\OpenServer\modules\database\MySQL-5.6.13\bin\mysqld.exe: ready for connections. Version: '5.6.13-log' socket: '' port: 3306 MySQL Community Server (GPL) 2013-09-25 15:02:54 1072 [Warning] InnoDB: Cannot open table drupal7/cache_bootstrap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:02:54 1072 [Warning] InnoDB: Cannot open table drupal7/semaphore from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:02:54 1072 [Warning] InnoDB: Cannot open table drupal7/semaphore from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:02:55 1072 [Warning] InnoDB: Cannot open table drupal7/cache_bootstrap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:02:55 1072 [Warning] InnoDB: Cannot open table drupal7/cache from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:02:55 1072 [Warning] InnoDB: Cannot open table drupal7/system from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:02:55 1072 [Warning] InnoDB: Cannot open table drupal7/semaphore from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/actions from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/authmap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/batch from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/block from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/block_custom from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/block_node_type from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/block_role from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/blocked_ips from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_admin_menu from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_block from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_bootstrap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_field from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_filter from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_form from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_image from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_l10n_update from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_menu from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_page from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_path from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_path_breadcrumbs from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_rules from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_token from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_update from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_views from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/cache_views_data from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/ctools_css_cache from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/ctools_object_cache from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/custom_breadcrumb from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/custom_breadcrumbs_paths from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/custom_breadcrumbs_taxonomy_term from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/custom_breadcrumbs_taxonomy_vocabulary from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/custom_breadcrumbs_views from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/custom_breadcrumbsapi from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/date_format_locale from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/date_format_type from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/date_formats from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_config from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_config_instance from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_body from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_date_begin from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_delivery_time from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_logo from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_menu from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_min_order from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_ocenka from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_rest from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_field_work_time from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_taxonomy_catalog from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_uc_catalog_image from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_data_uc_product_image from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_body from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_date_begin from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_delivery_time from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_logo from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_menu from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_min_order from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_ocenka from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_rest from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_field_work_time from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_taxonomy_catalog from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_uc_catalog_image from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/field_revision_uc_product_image from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/file_managed from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/file_usage from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/filter from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/filter_format from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/flood from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/history from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/image_effects from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/image_styles from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/l10n_update_file from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/l10n_update_project from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/languages from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/locales_source from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/locales_target from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/menu_custom from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/menu_links from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/menu_router from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/node from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/node_access from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/node_revision from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/node_type from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/path_breadcrumbs from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/queue from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/quicktabs from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/registry from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/registry_file from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/role from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/role_permission from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/rules_config from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/rules_dependencies from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/rules_tags from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/rules_trigger from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/search_dataset from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/search_index from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/search_node_links from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/search_total from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/semaphore from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/sequences from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/sessions from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/system from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/taxonomy_index from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/taxonomy_term_data from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/taxonomy_term_hierarchy from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/taxonomy_vocabulary from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_attribute_options from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_attributes from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_cart_link_clicks from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_cart_products from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_class_attribute_options from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_class_attributes from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_countries from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_admin_comments from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_comments from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_line_items from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_log from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_products from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_quotes from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_order_statuses from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_orders from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_packaged_products from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_packages from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_payment_receipts from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_adjustments from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_attributes from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_classes from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_features from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_kits from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_options from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_product_stock from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_products from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_quote_product_locations from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_quote_shipping_types from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_roles_expirations from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_roles_products from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_shipments from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_taxed_line_items from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_taxed_product_types from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_taxes from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/uc_zones from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/url_alias from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/users from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/users_roles from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/variable from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/views_display from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/views_view from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:11 1072 [Warning] InnoDB: Cannot open table drupal7/watchdog from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/actions from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/authmap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/batch from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/block from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/blocked_ips from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/block_custom from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/block_node_type from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/block_role from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_admin_menu from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_block from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_bootstrap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_field from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_filter from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_form from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_image from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_l10n_update from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_menu from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_page from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_path from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_path_breadcrumbs from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_rules from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_token from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_update from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:03:14 1072 [Warning] InnoDB: Cannot open table drupal7/cache_views from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/actions from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/authmap from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/batch from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/block from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/block_custom from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/block_node_type from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/block_role from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/blocked_ips from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 [Warning] InnoDB: Cannot open table drupal7/cache from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. 2013-09-25 15:04:05 1072 ... |
| 25.09.2013, 15:38:49 |
IceJOKERвот логи Читал? логSee http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. Видел? По ссылке ходил? читал? выполнял? Если да - то чего сюда пишешь? ... |
| 25.09.2013, 15:58:44 |
AkinaIceJOKERвот логи Читал? логSee http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem. Видел? По ссылке ходил? читал? выполнял? Если да - то чего сюда пишешь? нихрена не понял из документации что надо делать ... |
| 25.09.2013, 16:00:52 |
См. раздел Initialization Problems . Там не так много и просят. Только вместо удаления используй переименование - ну чтобы откатиться, ежели перестараешься. ... |
| 25.09.2013, 16:10:49 |
Akina, не помогло. создал новую базу(все ок), скопировал туда файлы таблиц - то же самое ... |
| 25.09.2013, 16:47:24 |
IceJOKERскопировал туда файлы таблицInnoDB. Вот просто скопировал файлы таблиц. Ага. Сделайте дамп БД из консоли, потом залейте его в новую, пустую свежесозданную друпаловскую БД 7-й версии без создания таблиц. ... |
| 25.09.2013, 17:48:25 |
Хотя там в таблицах, наверное, куча предопределённого дерьма... ... |
| 25.09.2013, 18:15:30 |
AkinaХотя там в таблицах, наверное, куча предопределённого дерьма...так оно же всё с дампом зальётся ... |
| 25.09.2013, 18:17:26 |
tanglir , я не об этом... я не знаю структурирования данных в друпале, а там есть как данные приложения, так и пользовательские, и небось это не одна БД... и вот тут не смешать бы всё в кучу. Впрочем, если есть исходное состояние (пусть и битое) - это нестрашно... ну придётся ещё раз переставить друпал. ... |
| 25.09.2013, 18:30:10 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1835979]: |
76ms |
48ms |
| others: | 239ms |
| total: | 413ms |
