помогите восстановить innodb
Всем привет... Проблемка, здохли ib_logfile0 и ib_logfile1.. бекап 1-1.5 месячной давности - т.е. не катит :( ibdata1 и папка с *.frm *.MYD .MYI уцелели.. MyISAM таблицы живы.. всё хорошо. с innodb проблемы при старте мускула mysql140111 0:16:50 InnoDB: Error: page 5 log sequence number 720903591713 InnoDB: is in the future! Current system log sequence number 297407794. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html InnoDB: for more information. 140111 0:16:50 InnoDB: Error: page 6 log sequence number 720900344500 InnoDB: is in the future! Current system log sequence number 297407794. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html InnoDB: for more information. 140111 0:16:50 InnoDB: Error: page 131121 log sequence number 720900344500 InnoDB: is in the future! Current system log sequence number 297407794. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html InnoDB: for more information. 140111 0:16:50 InnoDB: Error: page 45 log sequence number 744262977670 InnoDB: is in the future! Current system log sequence number 297407794. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html forcing-innodb-recovery 1-6 пробовал ;( слил на рабочий комп, через "Recovery Toolbox for MySql" открылось всё, все данные на месте, но триал версия не даёт делать экспорт дампа :( идеи? советы? зы: да, нужно делать чаще бекапы, да и предыстория нудная и длинная :)) ... |
| 11.01.2014, 01:55:30 |
sfzzz, Тут приводится несколько рецептов. ... |
| 11.01.2014, 03:13:49 |
сервер без опции innodb_file_per_table получается там половина способов не катит мб кто подскажет как отредактировать (или удалить) nnoDB: Error: page 5 log sequence number 720903591713 InnoDB: is in the future! Current system log sequence number 297407794. ... |
| 11.01.2014, 11:51:27 |
sfzzzсервер без опции innodb_file_per_table получается там половина способов не катит Как это не катит? :-) Для InnoDB recovery tool вообще все равно innodb_file_per_table ON или OFF. Разница только в том, где искать данные. sfzzzмб кто подскажет как отредактировать (или удалить) nnoDB: Error: page 5 log sequence number 720903591713 InnoDB: is in the future! Current system log sequence number 297407794. Но в Вашем случае не все так страшно. То, что неверный LSN - плохо, но не смертельно. Если таблица читается (select * from table не роняет MySQL), то эта ошибка сама уйдет, как только соответствующая страница будет модифицирована. Для хорошего сна можете перестроить индексы, на каждой таблице запустите такой запрос. ALTER TABLE t1 ENGINE INNODB; Если все пройдет без падений - можете спать спокойно. ... |
| 27.01.2014, 21:05:57 |
Aleksandr Kuzminsky, что-то много таких страниц и везде близкие числа sequence number. так что там похоже пытались подменять одни файлы другими. Ох не уйдет эта ошибка. ... |
| 28.01.2014, 00:27:42 |
netwindAleksandr Kuzminsky, что-то много таких страниц и везде близкие числа sequence number. так что там похоже пытались подменять одни файлы другими. Ох не уйдет эта ошибка. Тогда "ALTER TABLE t1 ENGINE INNODB" Ваш друг. ... |
| 28.01.2014, 00:38:08 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1835334]: |
269ms |
46ms |
| others: | 199ms |
| total: | 550ms |
