Че за ошибка такая ?
#38668655
Ссылка:
javajdbc,
пропатчил теперь в логе вот такое! Че дальше ? )
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68.
140612 22:43:06 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
140612 22:43:07 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
140612 22:43:07 [Note] InnoDB: Using mutexes to ref count buffer pool pages
140612 22:43:07 [Note] InnoDB: The InnoDB memory heap is disabled
140612 22:43:07 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
140612 22:43:07 [Note] InnoDB: Compressed tables use zlib 1.2.3
140612 22:43:07 [Note] InnoDB: Using Linux native AIO
140612 22:43:07 [Note] InnoDB: Using CPU crc32 instructions
140612 22:43:07 [Note] InnoDB: Initializing buffer pool, size = 128.0M
140612 22:43:07 [Note] InnoDB: Completed initialization of buffer pool
140612 22:43:07 [Note] InnoDB: Highest supported file format is Barracuda.
140612 22:43:08 [Note] InnoDB: 128 rollback segment(s) are active.
140612 22:43:08 [Note] InnoDB: Waiting for purge to start
140612 22:43:08 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.17-65.0 started; log sequence number 6652549566
140612 22:43:08 [Note] Plugin 'FEEDBACK' is disabled.
140612 22:43:08 [ERROR] Missing system table mysql.roles_mapping; please run mysql_upgrade to create it
140612 22:43:08 [ERROR] Column count of mysql.events_waits_current is wrong. Expected 19, found 16. Created with MariaDB 50536, now running 100011. Please us
140612 22:43:08 [ERROR] Column count of mysql.events_waits_history is wrong. Expected 19, found 16. Created with MariaDB 50536, now running 100011. Please us
140612 22:43:08 [ERROR] Column count of mysql.events_waits_history_long is wrong. Expected 19, found 16. Created with MariaDB 50536, now running 100011. Plea
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_host_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Incorrect definition of table performance_schema.events_waits_summary_by_thread_by_event_name: expected column 'THREAD_ID' at positio
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_user_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_account_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Column count of mysql.file_summary_by_event_name is wrong. Expected 23, found 5. Created with MariaDB 50536, now running 100011. Plea
140612 22:43:08 [ERROR] Column count of mysql.file_summary_by_instance is wrong. Expected 25, found 6. Created with MariaDB 50536, now running 100011. Please
140612 22:43:08 [ERROR] Native table 'performance_schema'.'host_cache' has the wrong structure
140612 22:43:08 [ERROR] Incorrect definition of table performance_schema.mutex_instances: expected column 'LOCKED_BY_THREAD_ID' at position 2 to have type bi
140612 22:43:08 [ERROR] Native table 'performance_schema'.'objects_summary_global_by_type' has the wrong structure
140612 22:43:08 [ERROR] Incorrect definition of table performance_schema.rwlock_instances: expected column 'WRITE_LOCKED_BY_THREAD_ID' at position 2 to have
140612 22:43:08 [ERROR] Native table 'performance_schema'.'setup_actors' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'setup_objects' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'table_io_waits_summary_by_index_usage' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'table_io_waits_summary_by_table' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'table_lock_waits_summary_by_table' has the wrong structure
140612 22:43:08 [ERROR] Column count of mysql.threads is wrong. Expected 14, found 3. Created with MariaDB 50536, now running 100011. Please use mysql_upgrad
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_current' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_history' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_history_long' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_summary_by_thread_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_summary_by_account_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_summary_by_user_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_summary_by_host_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_stages_summary_global_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_current' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_history' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_history_long' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_summary_by_thread_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_summary_by_account_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_summary_by_user_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_summary_by_host_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_summary_global_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'events_statements_summary_by_digest' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'users' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'accounts' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'hosts' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'socket_instances' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'socket_summary_by_instance' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'socket_summary_by_event_name' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'session_connect_attrs' has the wrong structure
140612 22:43:08 [ERROR] Native table 'performance_schema'.'session_account_connect_attrs' has the wrong structure
140612 22:43:08 [ERROR] Incorrect definition of table mysql.event: expected column 'sql_mode' at position 14 to have type set('REAL_AS_FLOAT','PIPES_AS_CONCAT','ANSI_QUOTES','IGNORE_SPACE','IGNORE_BAD_TABLE_OPTIONS','ONLY_FULL_GROUP_BY','NO_UNSIGNED_SUBTRACTION','NO_DIR_IN_CREATE','POSTGRESQL','ORACLE','MSSQL','DB2','MAXDB','NO_KEY_OPTIONS','NO_TABLE_OPTIONS','NO_FIELD_OPTIONS','MYSQL323','MYSQL40','ANSI','NO_AUTO_VALUE_ON_ZERO','NO_BACKSLASH_ESCAPES','STRICT_TRANS_TABLES','STRICT_ALL_TABLES','NO_ZERO_IN_DATE','NO_ZERO_DATE','INVALID_DATES','ERROR_FOR_DIVISION_BY_ZERO','TRADITIONAL','NO_AUTO_CREATE_USER','HIGH_NOT_PRECEDENCE','NO_ENGINE_SUBSTITUTION','PAD_CHAR_TO_FULL_LENGTH'), found type set('REAL_AS_FLOAT','PIPES_AS_CONCAT','ANSI_QUOTES','IGNORE_SPACE','NOT_USED','ONLY_FULL_GROUP_BY','NO_UNSIGNED_SUBTRACTION','NO_DIR_IN_CREATE','POSTGRESQL','ORACLE','MSSQL','DB2','MAXDB','NO_KEY_OPTIONS','NO_TABLE_OPTIONS','NO_FIELD_OPTIONS','MYSQL323','MYSQL40','ANSI','NO_AUTO_VALUE_ON_ZERO','NO_BACKSLASH_ESCAPES','STRICT_TRANS_TABLES','STRICT_A
140612 22:43:08 [ERROR] Event Scheduler: An error occurred when initializing system tables. Disabling the Event Scheduler.
140612 22:43:08 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1146: Table 'mysql.gtid_slave_pos' doesn't exist
140612 22:43:08 [Note] /usr/libexec/mysqld: ready for connections.
Version: '10.0.11-MariaDB' socket: '/var/lib/mysql/mysql.sock' port: 0 MariaDB Server
