inner join c несколькими выборками из одной таблицы
Подскажите, есть запрос select staff.fio from wp_db_staff as staff inner join wp_db_link as link ON staff.id = link.id_user inner join wp_db_object as object ON object.id = link.id_object inner join wp_db_spec as spec ON spec.id = link.id_spec WHERE staff.mark = 5 AND object.id = 11 AND spec.id = 4 Так всё работает, но не работает, если я добавляю условие неважно к какой таблице с полем, например select staff.fio from wp_db_staff as staff inner join wp_db_link as link ON staff.id = link.id_user inner join wp_db_object as object ON object.id = link.id_object inner join wp_db_spec as spec ON spec.id = link.id_spec WHERE staff.mark = 5 AND object.id = 11 AND spec.id = 4 AND object.id = 12 Так ничего не находит. Хотя должно. Где ошибка ? ... |
| 27.06.2014, 17:30:43 |
andrey24mayПодскажите, есть запрос select staff.fio from wp_db_staff as staff inner join wp_db_link as link ON staff.id = link.id_user inner join wp_db_object as object ON object.id = link.id_object inner join wp_db_spec as spec ON spec.id = link.id_spec WHERE staff.mark = 5 AND object.id = 11 AND spec.id = 4 Так всё работает, но не работает, если я добавляю условие неважно к какой таблице с полем, например select staff.fio from wp_db_staff as staff inner join wp_db_link as link ON staff.id = link.id_user inner join wp_db_object as object ON object.id = link.id_object inner join wp_db_spec as spec ON spec.id = link.id_spec WHERE staff.mark = 5 AND object.id = 11 AND spec.id = 4 AND object.id = 12 Так ничего не находит. Хотя должно. Где ошибка ? серьёзно??? должно??? --------------------------------!!!!!!!!!!!!!!!!!!---------------------------!!!!!!!!!!!!!!!!!! WHERE staff.mark = 5 AND object.id = 11 AND spec.id = 4 AND object.id = 12 ... |
| 27.06.2014, 18:23:52 |
серьёзно??? должно??? -------------------------------------------!!!!!!!!!!!!!!!!!!---------------------------!!!!!!!!!!!!!!!!!! WHERE staff.mark = 5 AND object.id = 11 AND spec.id = 4 AND object.id = 12 == object.id = 11 AND object.id = 12 ... |
| 27.06.2014, 18:24:40 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1834598]: |
43ms |
44ms |
| others: | 203ms |
| total: | 334ms |
