не запускатся mysql
ночью что то произошло и перестал запускаться mysql сейчас при запуске в логе пишет 141121 10:57:02 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 141121 10:57:02 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead. 141121 10:57:03 InnoDB: Initializing buffer pool, size = 8.0M 141121 10:57:03 InnoDB: Completed initialization of buffer pool 141121 10:57:03 InnoDB: Started; log sequence number 0 46200942 141121 10:57:03 [Note] Recovering after a crash using mysql-bin 141121 10:57:03 [Note] Starting crash recovery... 141121 10:57:03 [Note] Crash recovery finished. 08:57:03 UTC - mysqld got signal 11 ; This could be because you hit a bug. It is also possible that this binary or one of the libraries it was linked against is corrupt, improperly built, or misconfigured. This error can also be caused by malfunctioning hardware. We will try our best to scrape up some info that will hopefully help diagnose the problem, but since we have already crashed, something is definitely wrong and this may fail. key_buffer_size=268435456 read_buffer_size=1048576 max_used_connections=0 max_threads=151 thread_count=0 connection_count=0 It is possible that mysqld could use up to key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 572371 K bytes of memory Hope that's ok; if not, decrease some variables in the equation. Thread pointer: 0x0 Attempting backtrace. You can use the following information to find out where mysqld died. If you see no messages after this, something went terribly wrong... stack_bottom = 0 thread_stack 0x30000 /usr/libexec/mysqld(my_print_stacktrace+0x2e) [0x84c6d3e] /usr/libexec/mysqld(handle_fatal_signal+0x484) [0x82ec8b4] [0x516400] The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains information that should help you find out what is causing the crash. 141121 10:57:03 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended что делать? ... |
| 21.11.2014, 12:00:35 |
не запускатся mysql
yarnikчто делать? перевести сообщение об ошибке. Особенно обратить внимание на слова авторIt is also possible that this binary or one of the libraries it was linked against is corrupt, improperly built, or misconfigured. This error can also be caused by malfunctioning hardware. ... |
| 21.11.2014, 12:11:43 |
не запускатся mysql
это свзяно с удалением бинарных файлов, если их удалить вылазит такое: 141121 11:10:58 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 141121 11:10:58 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead. 141121 11:10:58 InnoDB: Initializing buffer pool, size = 8.0M 141121 11:10:58 InnoDB: Completed initialization of buffer pool 141121 11:10:58 InnoDB: Started; log sequence number 0 46200942 ^G/usr/libexec/mysqld: File './mysql-bin.000002' not found (Errcode: 2) 141121 11:10:58 [ERROR] Failed to open log (file './mysql-bin.000002', errno 2) 141121 11:10:58 [ERROR] Could not open log file 141121 11:10:58 [ERROR] Can't init tc log 141121 11:10:58 [ERROR] Aborting 141121 11:10:58 InnoDB: Starting shutdown... 141121 11:11:03 InnoDB: Shutdown completed; log sequence number 0 46200942 141121 11:11:03 [Note] /usr/libexec/mysqld: Shutdown complete 141121 11:11:03 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended если вернуть, то получаю ошибку с первого сообщения ... |
| 21.11.2014, 12:13:41 |
не запускатся mysql
решилось, если удалить все бинарные и mysql-bin.index, то должно заработать + отключение и удаление http://blog.kron-net.ru/archives/320 ... |
| 21.11.2014, 13:11:50 |
не запускатся mysql
yarnik, да не похоже. скорее, это две разные ошибки с разными причинами. первая ошибка может еще вернуться. ... |
| 21.11.2014, 13:40:45 |
не запускатся mysql
а хотя, понятно что происходит : если эта ошибка при каждом последующем запуске, то получается, данные в binlog-ах испортились один раз и ошибка связана с непредвиденным содержимым, которое mysqld не может обработать и вылетает по signal 11. ... |
| 21.11.2014, 13:46:42 |
start [/forum/search_topic.php?author=nx6600&author_mode=last_posts&do_search=1]: |
38ms |
54ms |
| others: | 825ms |
| total: | 987ms |
