Удаление с EXISTS
Подскажите, в чем ошибка? Код: sql 1. 2. 3. авторYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'tob WHERE trans_object_type = 'wagon' AND NOT EXISTS (SELECT * FROM wagon_card' at line 1 ... |
| 28.05.2015, 15:49:51 |
Удаление с EXISTS
Код: sql 1. 2. 3. 4. 5. ... |
| 28.05.2015, 15:55:56 |
Удаление с EXISTS
Akina Код: sql 1. 2. 3. 4. 5. без алиасов? ... |
| 28.05.2015, 16:00:06 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1833146]: |
50ms |
36ms |
| others: | 286ms |
| total: | 422ms |
