Не создает файл резервной копии БД
D:\web\server2go\server\mysql\bin>mysql --port=7188 -u root CREATE DATABASE rental; USE rental; CREATE TABLE dvd( dvd_id INT(11) UNSIGNED AUTO_INCREMENT, title VARCHAR(255), production_year YEAR, PRIMARY KEY(dvd_id)); CREATE TABLE customer( customer_id INT(11) UNSIGNED AUTO_INCREMENT, first_name VARCHAR(255), last_name VARCHAR(255), passport_code INT(11), registration_date DATE, PRIMARY KEY(customer_id)); CREATE TABLE offer( offer_id INT(11) UNSIGNED AUTO_INCREMENT, dvd_id INT(11) UNSIGNED, customer_id INT(11) UNSIGNED, offer_date DATE, return_date DATE, PRIMARY KEY(offer_id)); INSERT INTO dvd (title, production_year) VALUES ('Hills have eyes', 2002), ('Hills have eyes 2', 2007), ('6 demons of emily', 2003), ('The conjuring', 2013), ('Hostel 2', 2007), ('Hostel', 2005), ('Hostel 3', 2011), ('London boulevard', 2010), ('Choose', 2010), ('White Lion', 2010), ('Moby dick', 2010); INSERT INTO customer (first_name, last_name, passport_code, registration_date) VALUES ('Ivanov', 'Ivan', 9905123456, '2015-05-01'), ('Petrov', 'Petr', 9901321465, '2015-05-02'), ('Ivanov', 'Petr', 9902124365, '2015-05-03'), ('Petrov', 'Ivan', 9907311265, '2015-05-03'), ('Belousov', 'Evgeniy', 9901311250, '2015-05-01'), ('Mihailov', 'Pavel', 9500310251, '2015-05-01'), ('Pozdeev', 'Sergey', 9901310000, '2015-05-03'); INSERT INTO offer (dvd_id, customer_id, offer_date, return_date) VALUES ('1', '1', '2015-05-01', '2015-05-02'), ('2', '1', '2015-05-01', '2015-05-04'), ('3', '2', '2015-05-02', '2015-05-03'), ('4', '3', '2015-05-03', '2015-05-04'), ('5', '4', '2015-05-03', '2015-05-05'), ('6', '4', '2015-05-03', '2015-05-04'), ('7', '5', '2015-05-01', '2015-05-02'), ('8', '5', '2015-05-01', '2015-05-04'), ('9', '6', '2015-05-01', '2015-05-02'), ('10', '6', '2015-05-01', '2015-05-02'), ('11', '7', '2015-05-03', '2015-05-05'); LOCK TABLES dvd READ, customer READ, offer READ; mysqldump -u root -p rental > rental.sql Пишет ошибку: скриншот ... |
| 08.08.2015, 13:33:56 |
mysqldump - это не запрос, а команда (или exe-файл, если хотите) ... |
| 08.08.2015, 13:48:09 |
vkle, по-конкретнее можете написать, что вы имеете в виду? ... |
| 08.08.2015, 14:03:38 |
Откройте в проводнике каталог, откуда запускали команду mysql и посмотрите, что там есть ещё. ... |
| 08.08.2015, 14:08:18 |
vkle, какбЭ всё равно не понятно, если я запускаю эту команду из проводника, то как же я смогу указать в ней файл, в который мне копировать мою БД? ... |
| 08.08.2015, 17:14:40 |
homosapiens1985vkle, какбЭ всё равно не понятно, если я запускаю эту команду из проводника, то как же я смогу указать в ней файл, в который мне копировать мою БД?Речь шла о том, что ее увидеть (а не запускать) можно в проводнике. Т.е. это такая же обычная программа, как и множество других, а не команда консольного клиента MySQL. А запускать надо из командного окна ОС или из cmd-файла. ... |
| 08.08.2015, 17:30:27 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1832835]: |
63ms |
46ms |
| others: | 223ms |
| total: | 380ms |
