ERROR 1452
Помогите разобраться в чем дело. Пытаюсь разобраться в чужой базе. Не могу заполнить одну таблицу(route_has_station_has_seat ). Мешает ограничение внешнего ключа, в других таблицах ограничения тоже есть. Все айдишники ставил на своих местах. INSERT INTO country (idcountry, country) VALUES (1,"Барановичи"); INSERT INTO station (idstation,name,city,country_idcountry) VALUES (6,"Минск","Минск",1); INSERT INTO train(idtrain,number) VALUES (1,"409Д"); INSERT INTO wagon(idwagon,number,type,train_idtrain) VALUES (7,7,6,1);/*типы вагонов от 1 до 6*/ INSERT INTO seat (number,wagon_idwagon) VALUES (1,1); INSERT INTO route(idroute) VALUES (1); INSERT INTO driver (iddriver,name,surname,birth_date,phone_number) VALUES (1,"Сергей","Алексеев","1970.02.01","+375297652305"); INSERT INTO route_has_train (route_idroute,train_idtrain,driver_iddriver) VALUES (1,1,1); INSERT INTO route_has_station (route_idroute,station_idstation,arriveTime,departTime,numberStation) VALUES (1,2,"2015-01-15 12:10:00","2015-01-15 15:10:00",20); INSERT INTO user (iduser,station_idstation,login,password,name,surname) VALUES (2,1,'user','user','Андрей','Скворцов'); INSERT INTO ticket (idticket,firststation,laststation,user_iduser,time,cost) VALUES (2,6,2,1,now(),17500); INSERT INTO route_has_station_has_seat (route_has_station_route_idroute,route_has_station_station_idstation,route_has_station_numberStation,seat_wagon_idwagon,seat_number,cost,access,ticket_idticket) VALUES (1,6,20,1,5,17500,1,2); INSERT INTO country (idcountry, country) VALUES (1,"Барановичи"); INSERT INTO station (idstation,name,city,country_idcountry) VALUES (6,"Минск","Минск",1); INSERT INTO train(idtrain,number) VALUES (1,"409Д"); INSERT INTO wagon(idwagon,number,type,train_idtrain) VALUES (7,7,6,1);/*типы вагонов от 1 до 6*/ INSERT INTO seat (number,wagon_idwagon) VALUES (1,1); INSERT INTO route(idroute) VALUES (1); INSERT INTO driver (iddriver,name,surname,birth_date,phone_number) VALUES (1,"Сергей","Алексеев","1970.02.01","+375297652305"); INSERT INTO route_has_train (route_idroute,train_idtrain,driver_iddriver) VALUES (1,1,1); INSERT INTO route_has_station (route_idroute,station_idstation,arriveTime,departTime,numberStation) VALUES (1,2,"2015-01-15 12:10:00","2015-01-15 15:10:00",20); INSERT INTO user (iduser,station_idstation,login,password,name,surname) VALUES (2,1,'user','user','Андрей','Скворцов'); INSERT INTO ticket (idticket,firststation,laststation,user_iduser,time,cost) VALUES (2,6,2,1,now(),17500); /*Здесь ошибка*/ INSERT INTO route_has_station_has_seat (route_has_station_route_idroute,route_has_station_station_idstation,route_has_station_numberStation,seat_wagon_idwagon,seat_number,cost,access,ticket_idticket) VALUES (1,6,20,1,5,17500,1,2); ... |
| 14.12.2015, 02:29:37 |
ERROR 1452
Код самой базы -- MySQL Script generated by MySQL Workbench -- 12/13/14 16:18:30 -- Model: New Model Version: 1.0 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0; SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0; SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='TRADITIONAL,ALLOW_INVALID_DATES'; -- ----------------------------------------------------- -- Schema CourseProgect_db -- ----------------------------------------------------- CREATE SCHEMA IF NOT EXISTS `CourseProgect_db` DEFAULT CHARACTER SET utf8 COLLATE utf8_general_ci ; USE `CourseProgect_db` ; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`train` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`train` ( `idtrain` INT NOT NULL AUTO_INCREMENT, `number` VARCHAR(25) NULL, PRIMARY KEY (`idtrain`)) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`country` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`country` ( `idcountry` INT NOT NULL, `country` VARCHAR(45) NOT NULL, PRIMARY KEY (`idcountry`)) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`station` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`station` ( `idstation` INT NOT NULL AUTO_INCREMENT, `name` VARCHAR(45) NULL, `city` VARCHAR(45) NULL, `country_idcountry` INT NOT NULL, PRIMARY KEY (`idstation`), INDEX `name_idx` (`name` ASC), INDEX `city_idx` (`city` ASC), UNIQUE INDEX `name_UNIQUE` (`name` ASC), INDEX `fk_station_country1_idx` (`country_idcountry` ASC), CONSTRAINT `fk_station_country1` FOREIGN KEY (`country_idcountry`) REFERENCES `CourseProgect_db`.`country` (`idcountry`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`route` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`route` ( `idroute` INT NOT NULL AUTO_INCREMENT, PRIMARY KEY (`idroute`)) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`wagon` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`wagon` ( `idwagon` INT NOT NULL AUTO_INCREMENT, `number` INT NOT NULL, `type` ENUM('general','seating','second-class','compartment','sv','soft') NULL, `train_idtrain` INT NOT NULL, PRIMARY KEY (`idwagon`), INDEX `fk_wagon_train1_idx` (`train_idtrain` ASC), CONSTRAINT `fk_wagon_train1` FOREIGN KEY (`train_idtrain`) REFERENCES `CourseProgect_db`.`train` (`idtrain`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`route_has_station` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`route_has_station` ( `route_idroute` INT NOT NULL, `station_idstation` INT NOT NULL, `arriveTime` DATETIME NULL, `departTime` DATETIME NULL, `numberStation` INT NOT NULL, PRIMARY KEY (`route_idroute`, `station_idstation`, `numberStation`), INDEX `fk_route_has_station_station1_idx` (`station_idstation` ASC), INDEX `fk_route_has_station_route1_idx` (`route_idroute` ASC), CONSTRAINT `fk_route_has_station_route1` FOREIGN KEY (`route_idroute`) REFERENCES `CourseProgect_db`.`route` (`idroute`) ON DELETE CASCADE ON UPDATE CASCADE, CONSTRAINT `fk_route_has_station_station1` FOREIGN KEY (`station_idstation`) REFERENCES `CourseProgect_db`.`station` (`idstation`) ON DELETE CASCADE ON UPDATE CASCADE) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`driver` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`driver` ( `iddriver` INT NOT NULL, `name` VARCHAR(45) NULL, `surname` VARCHAR(45) NULL, `birth_date` DATE NULL, `phone_number` VARCHAR(15) NULL, PRIMARY KEY (`iddriver`)) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`route_has_train` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`route_has_train` ( `route_idroute` INT NOT NULL, `train_idtrain` INT NOT NULL, `driver_iddriver` INT NOT NULL, PRIMARY KEY (`route_idroute`, `train_idtrain`), INDEX `fk_route_has_train_train1_idx` (`train_idtrain` ASC), INDEX `fk_route_has_train_route1_idx` (`route_idroute` ASC), INDEX `fk_route_has_train_driver1_idx` (`driver_iddriver` ASC), CONSTRAINT `fk_route_has_train_route1` FOREIGN KEY (`route_idroute`) REFERENCES `CourseProgect_db`.`route` (`idroute`) ON DELETE CASCADE ON UPDATE CASCADE, CONSTRAINT `fk_route_has_train_train1` FOREIGN KEY (`train_idtrain`) REFERENCES `CourseProgect_db`.`train` (`idtrain`) ON DELETE CASCADE ON UPDATE CASCADE, CONSTRAINT `fk_route_has_train_driver1` FOREIGN KEY (`driver_iddriver`) REFERENCES `CourseProgect_db`.`driver` (`iddriver`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`seat` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`seat` ( `number` INT NOT NULL, `wagon_idwagon` INT NOT NULL, PRIMARY KEY (`wagon_idwagon`, `number`), CONSTRAINT `fk_seat_wagon1` FOREIGN KEY (`wagon_idwagon`) REFERENCES `CourseProgect_db`.`wagon` (`idwagon`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`user` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`user` ( `iduser` INT NOT NULL, `station_idstation` INT NOT NULL, `login` VARCHAR(45) NOT NULL, `password` VARCHAR(45) NOT NULL, `name` VARCHAR(45) NULL, `surname` VARCHAR(45) NULL, PRIMARY KEY (`iduser`), UNIQUE INDEX `login_UNIQUE` (`login` ASC), UNIQUE INDEX `password_UNIQUE` (`password` ASC), INDEX `fk_user_station1_idx` (`station_idstation` ASC), CONSTRAINT `fk_user_station1` FOREIGN KEY (`station_idstation`) REFERENCES `CourseProgect_db`.`station` (`idstation`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`ticket` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`ticket` ( `idticket` INT NOT NULL AUTO_INCREMENT, `firststation` INT NOT NULL, `laststation` INT NOT NULL, `user_iduser` INT NOT NULL, `time` DATETIME NULL, `cost` INT NULL, PRIMARY KEY (`idticket`), INDEX `fk_ticket_station1_idx` (`firststation` ASC), INDEX `fk_ticket_station2_idx` (`laststation` ASC), INDEX `fk_ticket_user1_idx` (`user_iduser` ASC), CONSTRAINT `fk_ticket_station1` FOREIGN KEY (`firststation`) REFERENCES `CourseProgect_db`.`station` (`idstation`) ON DELETE NO ACTION ON UPDATE NO ACTION, CONSTRAINT `fk_ticket_station2` FOREIGN KEY (`laststation`) REFERENCES `CourseProgect_db`.`station` (`idstation`) ON DELETE NO ACTION ON UPDATE NO ACTION, CONSTRAINT `fk_ticket_user1` FOREIGN KEY (`user_iduser`) REFERENCES `CourseProgect_db`.`user` (`iduser`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; -- ----------------------------------------------------- -- Table `CourseProgect_db`.`route_has_station_has_seat` -- ----------------------------------------------------- CREATE TABLE IF NOT EXISTS `CourseProgect_db`.`route_has_station_has_seat` ( `route_has_station_route_idroute` INT NOT NULL, `route_has_station_station_idstation` INT NOT NULL, `route_has_station_numberStation` INT NOT NULL, `seat_wagon_idwagon` INT NOT NULL, `seat_number` INT NOT NULL, `cost` INT NULL, `access` TINYINT(1) NULL, `ticket_idticket` INT NULL, PRIMARY KEY (`route_has_station_route_idroute`, `route_has_station_station_idstation`, `route_has_station_numberStation`, `seat_wagon_idwagon`, `seat_number`), INDEX `fk_route_has_station_has_seat_seat1_idx` (`seat_wagon_idwagon` ASC, `seat_number` ASC), INDEX `fk_route_has_station_has_seat_route_has_station1_idx` (`route_has_station_route_idroute` ASC, `route_has_station_station_idstation` ASC, `route_has_station_numberStation` ASC), INDEX `fk_route_has_station_has_seat_ticket1_idx` (`ticket_idticket` ASC), CONSTRAINT `fk_route_has_station_has_seat_route_has_station1` FOREIGN KEY (`route_has_station_route_idroute` , `route_has_station_station_idstation` , `route_has_station_numberStation`) REFERENCES `CourseProgect_db`.`route_has_station` (`route_idroute` , `station_idstation` , `numberStation`) ON DELETE CASCADE ON UPDATE CASCADE, CONSTRAINT `fk_route_has_station_has_seat_seat1` FOREIGN KEY (`seat_wagon_idwagon` , `seat_number`) REFERENCES `CourseProgect_db`.`seat` (`wagon_idwagon` , `number`) ON DELETE NO ACTION ON UPDATE NO ACTION, CONSTRAINT `fk_route_has_station_has_seat_ticket1` FOREIGN KEY (`ticket_idticket`) REFERENCES `CourseProgect_db`.`ticket` (`idticket`) ON DELETE NO ACTION ON UPDATE NO ACTION) ENGINE = InnoDB; SET SQL_MODE=@OLD_SQL_MODE; SET FOREIGN_KEY_CHECKS=@OLD_FOREIGN_KEY_CHECKS; SET UNIQUE_CHECKS=@OLD_UNIQUE_CHECKS; ... |
| 14.12.2015, 02:31:01 |
ERROR 1452
Попробуйте отключить проверку внешних ключей перед записью данных Код: sql 1. ... |
| 14.12.2015, 02:51:11 |
ERROR 1452
zak820/*Здесь ошибка*/Ну так текст ошибки мы увидим или как? Тем более что это 1452, т.е. там явно должно быть указано, какой именно ФК дал отлуп. zak820спасибоЗачем вам тогда вообще ФК? :) Этот совет полезен только для загрузки данных, про которые абсолютно точно, на все 146% известно, что они согласованы - таких, как дампы. Но дампилки как правило и сами эту инструкцию пишут (ваш воркбенч, к примеру, это сделал - посмотрите внимательно на первые и последние строки), да ещё и добавляют возврат исходного значения этого параметра после загрузки, что как бы должно как бы намекать. ... |
| 14.12.2015, 11:30:32 |
ERROR 1452
tanglirНо дампилки как правило и сами эту инструкцию пишутДампилок - тьма развелось. Чего только ни присылают... Можно, конечно, сперва загружать зависимые таблицы, на которые ключ ссылается. Да геморно это под каждый присланный дамп перетасовывать последовательность загрузки таблиц. ... |
| 15.12.2015, 01:58:31 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1832377]: |
446ms |
41ms |
| others: | 198ms |
| total: | 722ms |
