Медленно обрабатывает запрос
Есть таблица : mysql> SHOW CREATE TABLE `raw`; +-------+------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+ | Table | Create Table | +-------+------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+ | raw | CREATE TABLE `raw` ( `unix_secs` int(11) unsigned NOT NULL DEFAULT '0', `unix_nsecs` int(11) unsigned NOT NULL DEFAULT '0', `sysuptime` int(11) unsigned NOT NULL DEFAULT '0', `exaddr` varchar(15) NOT NULL DEFAULT '0', `dpkts` int(11) unsigned NOT NULL DEFAULT '0', `doctets` int(11) unsigned NOT NULL DEFAULT '0', `srcaddr` varchar(15) NOT NULL DEFAULT '0', `dstaddr` varchar(15) NOT NULL DEFAULT '0', `srcport` smallint(5) unsigned NOT NULL DEFAULT '0', `dstport` smallint(5) unsigned NOT NULL DEFAULT '0', `prot` tinyint(3) unsigned NOT NULL DEFAULT '0' ) ENGINE=MyISAM DEFAULT CHARSET=latin1 | +-------+------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+ 1 row in set (0.02 sec) делаю запрос: select srcaddr and SUM(doctets) from raw where srcaddr = 'x.x.x.x'; И он выполняется 10 минут. Почты любой запрос выполняется 10 минут (select). Как диагностировать проблему? Заранее всем спасибо. ... |
| 22.06.2016, 17:55 |
GolthanaКак диагностировать проблему?показать для начала explain? ... |
| 24.06.2016, 11:15 |
Совсем вообще ни одного индекса не создано. Может все-таки почитать об базах данных что-нибудь общего назначения? ... |
| 24.06.2016, 13:20 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1831638]: |
417ms |
27ms |
| others: | 240ms |
| total: | 722ms |
