Как правильно оформить txt файл для импорта в таблицу.
Добрый день! Не получается импортировать данные и текстового файла в таблицу. Все записи skipped. Смотрел warnings вылезло следующее: Ввожу команду: mysql> load data local infile 'c:\\tmp\\milk1.txt' into table products; Query OK, 0 rows affected, 105 warnings (0.00 sec) Records: 21 Deleted: 0 Skipped: 21 Warnings: 105 вот что вывел show warnings; : ' for column 'product_id' at row 1 | value: '?product_id, name_product, quantity, shelf_life | Warning | 1261 | Row 1 doesn't contain data for all columns | | Warning | 1261 | Row 1 doesn't contain data for all columns | | Warning | 1261 | Row 1 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '0' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 2 | | Warning | 1261 | Row 2 doesn't contain data for all columns | | Warning | 1261 | Row 2 doesn't contain data for all columns | | Warning | 1261 | Row 2 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '1' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 3 | | Warning | 1261 | Row 3 doesn't contain data for all columns | | Warning | 1261 | Row 3 doesn't contain data for all columns | | Warning | 1261 | Row 3 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '2' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 4 | | Warning | 1261 | Row 4 doesn't contain data for all columns | | Warning | 1261 | Row 4 doesn't contain data for all columns | | Warning | 1261 | Row 4 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '3' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 5 | | Warning | 1261 | Row 5 doesn't contain data for all columns | | Warning | 1261 | Row 5 doesn't contain data for all columns | | Warning | 1261 | Row 5 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '4' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 6 | | Warning | 1261 | Row 6 doesn't contain data for all columns | | Warning | 1261 | Row 6 doesn't contain data for all columns | | Warning | 1261 | Row 6 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '5' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 7 | | Warning | 1261 | Row 7 doesn't contain data for all columns | | Warning | 1261 | Row 7 doesn't contain data for all columns | | Warning | 1261 | Row 7 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '6' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 8 | | Warning | 1261 | Row 8 doesn't contain data for all columns | | Warning | 1261 | Row 8 doesn't contain data for all columns | | Warning | 1261 | Row 8 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '7' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 9 | | Warning | 1261 | Row 9 doesn't contain data for all columns | | Warning | 1261 | Row 9 doesn't contain data for all columns | | Warning | 1261 | Row 9 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '8' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 10 | | Warning | 1261 | Row 10 doesn't contain data for all columns | | Warning | 1261 | Row 10 doesn't contain data for all columns | | Warning | 1261 | Row 10 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '9' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 11 | | Warning | 1261 | Row 11 doesn't contain data for all columns | | Warning | 1261 | Row 11 doesn't contain data for all columns | | Warning | 1261 | Row 11 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '10' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 12 | | Warning | 1261 | Row 12 doesn't contain data for all columns | | Warning | 1261 | Row 12 doesn't contain data for all columns | | Warning | 1261 | Row 12 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '11' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 13 | | Warning | 1261 | Row 13 doesn't contain data for all columns | | Warning | 1261 | Row 13 doesn't contain data for all columns | | Warning | 1261 | Row 13 doesn't contain data for all columns Привожу содержание импортируемого файла: name_product, quantity, shelf_date 'Кефир', '20', '2016-07-30' 'Молоко', '50', '2016-07-29' 'Сосиски', '12', '2016-08-12' 'Хлеб заводской', '36', '2016-07-27' 'Котлеты', '96', '2016-09-13' 'Творог', '60', '2016-07-30' 'Кумыс', '32', '2016-08-28' 'Сыр', '18', '2016-09-30' 'Сало', '203', '2016-09-30' 'Сметана', '60', '2016-08-22' 'Хлеб Семиреченский', '93', '2016-07-27' 'Булочка сдобная', '156', '2016-07-25' 'Пироженное картошка', '37', '2016-07-28' Пробовал добавить в текстовый файл ID (хотя по логике должно само присваиваться) Содержание файла с ID: product_id, name_product, quantity, shelf_life 1, "Кефир", 20, 2016-07-30 2, "Молоко", 50, 2016-07-25 3, "Сосиски", 12, 2016-08-12 4, "Хлеб заводской", 36, 2016-07-27 5, "Котлеты", 96, 2016-09-13 6,"Творог", 60, 2016-07-23 7, "Кумыс", 32, 2016-08-28 8, "Сыр", 18, 2016-09-30 9, "Сало", 203, 2016-09-30 10, "Сметана", 60, 2016-07-22 11, "Хлеб Семиреченский", 93, 2016-07-27 12, "Булочка сдобная", 156, 2016-07-25 13, "Пироженное картошка", 37, 2016-07-22 Вот результат команды: load data local infile 'c:\\tmp\\milk1.txt' into table products; Query OK, 0 rows affected, 105 warnings (0.00 sec) Records: 21 Deleted: 0 Skipped: 21 Warnings: 105 Вот что выводит команда show warnings; : mysql> show warnings; +---------+------+--------------------------------------------------------------------------------------------------------------+ | Level | Code | Message | +---------+------+--------------------------------------------------------------------------------------------------------------+ ' for column 'product_id' at row 1 | value: '?product_id, name_product, quantity, shelf_life | Warning | 1261 | Row 1 doesn't contain data for all columns | | Warning | 1261 | Row 1 doesn't contain data for all columns | | Warning | 1261 | Row 1 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '0' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 2 | | Warning | 1261 | Row 2 doesn't contain data for all columns | | Warning | 1261 | Row 2 doesn't contain data for all columns | | Warning | 1261 | Row 2 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '1' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 3 | | Warning | 1261 | Row 3 doesn't contain data for all columns | | Warning | 1261 | Row 3 doesn't contain data for all columns | | Warning | 1261 | Row 3 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '2' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 4 | | Warning | 1261 | Row 4 doesn't contain data for all columns | | Warning | 1261 | Row 4 doesn't contain data for all columns | | Warning | 1261 | Row 4 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '3' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 5 | | Warning | 1261 | Row 5 doesn't contain data for all columns | | Warning | 1261 | Row 5 doesn't contain data for all columns | | Warning | 1261 | Row 5 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '4' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 6 | | Warning | 1261 | Row 6 doesn't contain data for all columns | | Warning | 1261 | Row 6 doesn't contain data for all columns | | Warning | 1261 | Row 6 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '5' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 7 | | Warning | 1261 | Row 7 doesn't contain data for all columns | | Warning | 1261 | Row 7 doesn't contain data for all columns | | Warning | 1261 | Row 7 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '6' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 8 | | Warning | 1261 | Row 8 doesn't contain data for all columns | | Warning | 1261 | Row 8 doesn't contain data for all columns | | Warning | 1261 | Row 8 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '7' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 9 | | Warning | 1261 | Row 9 doesn't contain data for all columns | | Warning | 1261 | Row 9 doesn't contain data for all columns | | Warning | 1261 | Row 9 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '8' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 10 | | Warning | 1261 | Row 10 doesn't contain data for all columns | | Warning | 1261 | Row 10 doesn't contain data for all columns | | Warning | 1261 | Row 10 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '9' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 11 | | Warning | 1261 | Row 11 doesn't contain data for all columns | | Warning | 1261 | Row 11 doesn't contain data for all columns | | Warning | 1261 | Row 11 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '10' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 12 | | Warning | 1261 | Row 12 doesn't contain data for all columns | | Warning | 1261 | Row 12 doesn't contain data for all columns | | Warning | 1261 | Row 12 doesn't contain data for all columns | | Warning | 1062 | Duplicate entry '11' for key 'PRIMARY' | | Warning | 1265 | Data truncated for column 'product_id' at row 13 | | Warning | 1261 | Row 13 doesn't contain data for all columns | | Warning | 1261 | Row 13 doesn't contain data for all columns | | Warning | 1261 | Row 13 doesn't contain data for all columns | +---------+------+--------------------------------------------------------------------------------------------------------------+ 64 rows in set (0.00 sec) База пустая : mysql> describe products; +--------------+---------+------+-----+---------+-------+ | Field | Type | Null | Key | Default | Extra | +--------------+---------+------+-----+---------+-------+ | product_id | int(11) | NO | PRI | NULL | | | name_product | text | YES | | NULL | | | quantity | int(11) | YES | | NULL | | | shelf_life | date | YES | | NULL | | +--------------+---------+------+-----+---------+-------+ 4 rows in set (0.00 sec) Пните пожалуйста куда копать в чем загвоздка, только сильно не пинайте я взял задание на вакансию java junior и там по требованию нужно создать таблицы, наполнить их и написать запросы, MySQL изучал пару часов. Заранее спасибо! ... |
| 26.07.2016, 14:20 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1831543]: |
175ms |
37ms |
| others: | 223ms |
| total: | 484ms |
