Подскажите, что я не правильно делаю в запросе для MySQL
Запрос должен делать выборку value (ttlfrt) между задаваемыми значениями datetime Замучался искать ошибку возвращает error near 'select cast(sum(economy.ttlfrt * periodTime) as decimal(15,2)) from (...on line 16 +++ исходные данные: variables in date and time picker: perbeg, perend table economy: values: voynumber, int begin , datetime end, datetime ttlfrt, decimal Сам запрос ++++ select voynumber, begin, end, ROUND ((TIME_TO_SEC(TIMEDIFF(economy.begin, economy.end))/86400),4) as fullvoyTime, case when economy.begin < {perbeg} and economy.end > {perend} then TIME_TO_SEC(TIMEDIFF({perbeg}, {perend})) when economy.begin >= {perbeg} and economy.end <= {perend} then TIME_TO_SEC(TIMEDIFF( economy.begin, economy.end)) when economy.begin < {perbeg} and economy.end <= {perend} then TIME_TO_SEC(TIMEDIFF( {perbeg}, economy.end)) when economy.begin >= {perbeg} and economy.end > {perend} then TIME_TO_SEC(TIMEDIFF( economy.begin, {perend})) end as periodTime from economy where economy.begin <= {perbeg} and economy.end >= {perbeg} or economy.begin <= {perend} and economy.end >= {perbeg}, select cast(sum(economy.ttlfrt * periodTime) as decimal(15,2)) from ( select voynumber, ROUND ((TIME_TO_SEC(TIMEDIFF(economy.begin, economy.end))/86400),4) as fullvoyTime, case when economy.begin < {perbeg} and economy.end > {perend} then TIME_TO_SEC(TIMEDIFF({perbeg}, {perend})) when economy.begin >= {perbeg} and economy.end <= {perend} then TIME_TO_SEC(TIMEDIFF( economy.begin, economy.end)) when economy.begin < {perbeg} and economy.end <= {perend} then TIME_TO_SEC(TIMEDIFF( {perbeg}, economy.end)) when economy.begin >= {perbeg} and economy.end > {perend} then TIME_TO_SEC(TIMEDIFF( economy.begin, {perend})) end as periodTime, ttlfrt, ttlfrt / TIME_TO_SEC(TIMEDIFF( economy.begin, economy.end)) as tariff from economy where economy.begin <= {perbeg} and economy.end >= {perbeg} or economy.begin <= {perend} and economy.end >= {perbeg}) as final ... |
| 09.11.2016, 22:56 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1831225]: |
158ms |
45ms |
| others: | 251ms |
| total: | 503ms |
