You have an error in your SQL syntax;
MariaDB [(none)]> CREATE DATABASE [rabota7]; ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '[rabota7]' at line 1 ... |
| 23.11.2016, 12:46 |
В MySQL имена квотятся обратными кавычками, а не квадратными скобками. ... |
| 23.11.2016, 13:25 |
Я пишу так MariaDB [(none)]> MariaDB [(none)]> use dev_rabota7 Database changed MariaDB [dev_rabota7]> что дальше ... |
| 23.11.2016, 14:20 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1831172]: |
164ms |
40ms |
| others: | 194ms |
| total: | 448ms |
