сбой при обновлении mysql, восстановление БД
при обновлении mysql с неизвестно какой версии на 5.6 случился сбой. теперь крутит по циклу mysql_update в результате выдает ошибку: Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 62: Table 'mysql.innodb_table_stats' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 63: Unknown prepared statement handler (stmt) given to EXECUTE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 64: Unknown prepared statement handler (stmt) given to DEALLOCATE PREPARE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 66: Table 'mysql.innodb_index_stats' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 67: Unknown prepared statement handler (stmt) given to EXECUTE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 68: Unknown prepared statement handler (stmt) given to DEALLOCATE PREPARE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 81: Table 'mysql.slave_relay_log_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 82: Unknown prepared statement handler (stmt) given to EXECUTE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 83: Unknown prepared statement handler (stmt) given to DEALLOCATE PREPARE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 110: Table 'mysql.slave_master_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 111: Unknown prepared statement handler (stmt) given to EXECUTE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 112: Unknown prepared statement handler (stmt) given to DEALLOCATE PREPARE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 128: Table 'mysql.slave_worker_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 129: Unknown prepared statement handler (stmt) given to EXECUTE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1243 (HY000) at line 130: Unknown prepared statement handler (stmt) given to DEALLOCATE PREPARE Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1896: Table 'mysql.slave_master_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1897: Table 'mysql.slave_master_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1898: Table 'mysql.slave_master_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1899: Table 'mysql.slave_worker_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1900: Table 'mysql.slave_relay_log_info' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1904: Table 'mysql.innodb_table_stats' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: ERROR 1146 (42S02) at line 1908: Table 'mysql.innodb_index_stats' doesn't exist Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: FATAL ERROR: Upgrade failed Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: Upgrade failed Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: Shuting down protected MySQL Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: Final cleanup Nov 24 19:21:01 srvm mysql-systemd-helper[28527]: Something failed during upgrade, please check logs Nov 24 19:21:01 srvm systemd[1]: mysql.service: control process exited, code=exited status=1 Nov 24 19:21:01 srvm systemd[1]: Failed to start MySQL server. Nov 24 19:21:01 srvm systemd[1]: Unit mysql.service entered failed state. Nov 24 19:21:01 srvm systemd[1]: mysql.service holdoff time over, scheduling restart. Nov 24 19:21:01 srvm systemd[1]: Stopping MySQL server... Nov 24 19:21:01 srvm systemd[1]: Starting MySQL server... и по кругу... как можно поднять БД? есть и myisam и innodb... ... |
| 24.11.2016, 19:25 |
а бэкапа в виде дампа нет что ли? ... |
| 25.11.2016, 08:45 |
ну вот так вот получается что нет :( БД не так что б жизненно важная (система мониторинга), но при этом огромная, вот и работает на чем есть. В общем все починил - удалил все файлы на которые ругня была в логе что их нет, но при этом они были... потом запустил mysql_update. Прошло без ошибок и все заработало :) --- ... |
| 28.11.2016, 17:15 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1831152]: |
169ms |
29ms |
| others: | 199ms |
| total: | 438ms |
