Error 2013: Lost connection to MySQL server during query при mysqldump
Добрые день вопрос по базе данных mariadb, перешли с myisam на innodb и теперь при бекапе выдаёт ошибку mysqldump: Error 2013: Lost connection to MySQL server during query when dumping table `b_stat_city` at row: 4468018 Пробовал бекап с ключём --single-transaction тоже не помогает всё так же ошибка и на этой же таблице, может таблица с ошибкой и не пропускает дальше? ... |
| 23.12.2016, 11:40 |
Запрос check table b_stat_city; выдаёт туже ошибку вот лог 161223 01:18:57 mysqld_safe Number of processes running now: 0 161223 01:18:57 mysqld_safe mysqld restarted 161223 1:18:57 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release. 161223 1:18:57 [Note] /usr/libexec/mysqld (mysqld 5.5.44-MariaDB) starting as process 29544 ... 161223 1:18:57 InnoDB: The InnoDB memory heap is disabled 161223 1:18:57 InnoDB: Mutexes and rw_locks use GCC atomic builtins 161223 1:18:57 InnoDB: Compressed tables use zlib 1.2.7 161223 1:18:57 InnoDB: Using Linux native AIO 161223 1:18:57 InnoDB: Warning: innodb_file_io_threads is deprecated. Please use innodb_read_io_threads and innodb_write_io_threads instead 161223 1:18:57 InnoDB: Initializing buffer pool, size = 600.0M 161223 1:18:57 InnoDB: Completed initialization of buffer pool 161223 1:18:57 InnoDB: highest supported file format is Barracuda. InnoDB: Log scan progressed past the checkpoint lsn 16283368995 161223 1:18:57 InnoDB: Database was not shut down normally! InnoDB: Starting crash recovery. InnoDB: Reading tablespace information from the .ibd files... InnoDB: Restoring possible half-written data pages from the doublewrite InnoDB: buffer... InnoDB: Doing recovery: scanned up to log sequence number 16283371054 161223 1:19:02 InnoDB: Starting an apply batch of log records to the database... InnoDB: Progress in percents: 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 InnoDB: Apply batch completed 161223 1:19:02 InnoDB: Waiting for the background threads to start 161223 1:19:03 Percona XtraDB ( http://www.percona.com) 5.5.43-MariaDB-37.2 started; log sequence number 16283371054 161223 1:19:03 [Note] Plugin 'FEEDBACK' is disabled. 161223 1:19:03 [Note] Server socket created on IP: '0.0.0.0'. 161223 1:19:03 [Note] Event Scheduler: Loaded 0 events 161223 1:19:03 [Note] /usr/libexec/mysqld: ready for connections. Version: '5.5.44-MariaDB' socket: '/var/lib/mysql/mysql.sock' port: 3306 MariaDB Server ... |
| 23.12.2016, 11:41 |
austin123Запрос check table b_stat_city; выдаёт туже ошибку Думаю, что b_stat_city - это InnoDB. В таком случае подбором диапазонов первичного ключа сдампить данные. Потом перезапустить MySQL с innodb_force_recovery=[1-6] и дропнуть таблицу. ... |
| 17.01.2017, 07:12 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1830994]: |
146ms |
34ms |
| others: | 246ms |
| total: | 475ms |
