installing mysql. redhat 5
Добрый день. Устанавливаю mysql на redhat5 делаю все по инструкции https://dev.mysql.com/doc/refman/5.7/en/linux-installation-rpm.html не выходит. пишет о зависимостях.. автор[root@spb ~]# cat /etc/redhat-release Red Hat Enterprise Linux Server release 5.8 (Tikanga) [root@spb ~]# cd /home/sergey/distr/ [root@spb distr]# ls -l total 270740 -rw-r--r-- 1 sergey sergey 32730215 Mar 14 14:38 mysql-community-client-5.7.17-1.el5.x86_64.rpm -rw-r--r-- 1 sergey sergey 832644 Mar 14 14:55 mysql-community-common-5.7.17-1.el5.x86_64.rpm -rw-r--r-- 1 sergey sergey 2976198 Mar 14 14:55 mysql-community-libs-5.7.17-1.el5.x86_64.rpm -rw-r--r-- 1 sergey sergey 2215919 Mar 15 11:31 mysql-community-libs-compat-5.7.17-1.el5.x86_64.rpm -rw-r--r-- 1 sergey sergey 238187947 Mar 14 14:38 mysql-community-server-5.7.17-1.el5.x86_64.rpm [root@spb distr]# yum install mysql-community-{server,client,common,libs}-* Loaded plugins: katello, product-id, security, subscription-manager Updating certificate-based repositories. Unable to read consumer identity Setting up Install Process Examining mysql-community-server-5.7.17-1.el5.x86_64.rpm: mysql-community-server-5.7.17-1.el5.x86_64 Marking mysql-community-server-5.7.17-1.el5.x86_64.rpm to be installed Examining mysql-community-client-5.7.17-1.el5.x86_64.rpm: mysql-community-client-5.7.17-1.el5.x86_64 Marking mysql-community-client-5.7.17-1.el5.x86_64.rpm to be installed Examining mysql-community-common-5.7.17-1.el5.x86_64.rpm: mysql-community-common-5.7.17-1.el5.x86_64 Marking mysql-community-common-5.7.17-1.el5.x86_64.rpm to be installed Examining mysql-community-libs-5.7.17-1.el5.x86_64.rpm: mysql-community-libs-5.7.17-1.el5.x86_64 Marking mysql-community-libs-5.7.17-1.el5.x86_64.rpm to be installed Examining mysql-community-libs-compat-5.7.17-1.el5.x86_64.rpm: mysql-community-libs-compat-5.7.17-1.el5.x86_64 Marking mysql-community-libs-compat-5.7.17-1.el5.x86_64.rpm to be installed Resolving Dependencies --> Running transaction check ---> Package mysql-community-client.x86_64 0:5.7.17-1.el5 set to be updated ---> Package mysql-community-common.x86_64 0:5.7.17-1.el5 set to be updated --> Processing Dependency: mysql >= 5.7.9 for package: mysql-community-common ---> Package mysql-community-libs.x86_64 0:5.7.17-1.el5 set to be updated ---> Package mysql-community-libs-compat.x86_64 0:5.7.17-1.el5 set to be updated ---> Package mysql-community-server.x86_64 0:5.7.17-1.el5 set to be updated --> Finished Dependency Resolution mysql-community-common-5.7.17-1.el5.x86_64 from /mysql-community-common-5.7.17-1.el5.x86_64 has depsolving problems --> Missing Dependency: mysql >= 5.7.9 is needed by package mysql-community-common-5.7.17-1.el5.x86_64 (/mysql-community-common-5.7.17-1.el5.x86_ 64) Error: Missing Dependency: mysql >= 5.7.9 is needed by package mysql-community-common-5.7.17-1.el5.x86_64 (/mysql-community-common-5.7.17-1.el5.x86 _64) You could try using --skip-broken to work around the problem You could try running: package-cleanup --problems package-cleanup --dupes rpm -Va --nofiles --nodigest The program package-cleanup is found in the yum-utils package. [root@spb distr]# подскажите, что не так? ... |
| 15.03.2017, 11:48 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1830844]: |
181ms |
25ms |
| others: | 232ms |
| total: | 476ms |
