Проблема с установкой MySQL 5.7.21 на Windows 8
Всем привет. Скачал официальный pack с сайта https://dev.mysql.com/downloads/windows/installer/5.7.html Версия 5.7.21, до этого не было никаких установок. Выбрал Development конфигурацию и на предпоследнем шаге выдает ошибку http://prntscr.com/i7qddb LOG: авторBeginning configuration step: Stopping Server [if necessary] Starting process with command: C:\Program Files\MySQL\MySQL Server 5.7\bin\mysql.exe -uroot -p123456 --port 3306 -e"SET GLOBAL innodb_fast_shutdown = 0"... mysql: [Warning] Using a password on the command line interface can be insecure. ERROR 2003 (HY000): Can't connect to MySQL server on 'localhost' (10061) Process for mysql, with ID 6876, was started successfully and exited with code 1. Starting process with command: C:\Program Files\MySQL\MySQL Server 5.7\bin\mysqladmin.exe -uroot -p123456 --port 3306 shutdown... mysqladmin: [Warning] Using a password on the command line interface can be insecure. mysqladmin: connect to server at 'localhost' failed error: 'Can't connect to MySQL server on 'localhost' (10061)' Check that mysqld is running on localhost and that the port is 3306. You can check this by doing 'telnet localhost 3306' Process for mysqladmin, with ID 4748, was started successfully and exited with code 1. Ended configuration step: Stopping Server [if necessary] Beginning configuration step: Writing configuration file Ended configuration step: Writing configuration file Beginning configuration step: Updating firewall Attempting to create firewall rule with command: netsh.exe firewall delete portopening protocol=TCP port=3306 profile=ALL Adding firewall rule for MySQL57 on port 3306. Attempting to create firewall rule with command: netsh.exe firewall add portopening protocol=TCP port=3306 profile=ALL name=MySQL57 mode=ENABLE scope=ALL Unexpected response from netsh: Could not run process. Attempting to create firewall rule with command: netsh.exe advfirewall firewall add rule name="Port 3306" protocol=TCP localport=3306 dir=in action=allow Successfully added firewall rule. Ended configuration step: Updating firewall Beginning configuration step: Adjusting Windows service [if necessary] Attempting to grant Network Service require filesystem permissions. Granted permissions. Updating existing service Existing service updated Ended configuration step: Adjusting Windows service [if necessary] Beginning configuration step: Initializing Database [if necessary] Found existing data directory, no need for initialize the database. Ended configuration step: Initializing Database [if necessary] Beginning configuration step: Starting Server Attempting to start service MySQL57 Ended configuration step: Starting Server Beginning configuration step: Updating Start Menu Link Attempting to verify command-line client shortcut. Failed to verify command-line client shortcut. Ended configuration step: Updating Start Menu Link Подскажите, пожалуйста, в чем может быть проблема и как ее устранить? Спасибо Модератор: Тема перенесена из форума "Microsoft SQL Server". ... |
| 30.01.2018, 19:09 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1830091]: |
164ms |
27ms |
| others: | 230ms |
| total: | 464ms |
