Запрос UPDATE SELECT
Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. не работает. Выдает ошибку: авторYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE i.cargo_zone_id = ng.cargo_zone_id AND e.nomenclature_group_service_id IS' at line 7 ... |
| 19.02.2018, 10:23 |
svnvlad, https://dev.mysql.com/doc/refman/5.7/en/update.html Код: plaintext 1. 2. ... |
| 19.02.2018, 10:32 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1830049]: |
387ms |
39ms |
| others: | 237ms |
| total: | 711ms |
