powered by simpleCommunicator - 2.0.52     © 2025 Programmizd 02
Форумы / MySQL [игнор отключен] [закрыт для гостей] / Statistics - 99% времени выполенения запроса
2 сообщений из 2, страница 1 из 1
    #39775165
supermike
Есть один запрос, который создает система CMS Bitrix
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
SELECT
	COUNT('x') AS C
FROM
	b_iblock B
	INNER JOIN b_lang L ON B.LID=L.LID
	INNER JOIN b_iblock_element BE ON BE.IBLOCK_ID = B.ID
	LEFT JOIN b_iblock_property FP0 ON FP0.IBLOCK_ID = B.ID AND  FP0.CODE='ADDRESS_UR'
	LEFT JOIN b_iblock_property FP1 ON FP1.IBLOCK_ID = B.ID AND  FP1.CODE='SITE'
	LEFT JOIN b_iblock_property FP2 ON FP2.IBLOCK_ID = B.ID AND  FP2.CODE='COMP_EMAIL'
	LEFT JOIN b_iblock_property FP3 ON FP3.IBLOCK_ID = B.ID AND  FP3.CODE='COMP_PHONE'
	LEFT JOIN b_iblock_property FP4 ON FP4.IBLOCK_ID = B.ID AND  FP4.CODE='LAST_NAME'
	LEFT JOIN b_iblock_property FP5 ON FP5.IBLOCK_ID = B.ID AND  FP5.CODE='FIRST_NAME'
	LEFT JOIN b_iblock_property FP6 ON FP6.IBLOCK_ID = B.ID AND  FP6.CODE='MIDDLE_NAME'
	LEFT JOIN b_iblock_property FP7 ON FP7.IBLOCK_ID = B.ID AND  FP7.CODE='POSITION'
	LEFT JOIN b_iblock_property FP8 ON FP8.IBLOCK_ID = B.ID AND  FP8.CODE='EMAIL'
	LEFT JOIN b_iblock_property FP9 ON FP9.IBLOCK_ID = B.ID AND  FP9.CODE='PHONE'
	LEFT JOIN b_iblock_property FP10 ON FP10.IBLOCK_ID = B.ID AND  FP10.CODE='INTERESTS'
	LEFT JOIN b_iblock_property FP11 ON FP11.IBLOCK_ID = B.ID AND  FP11.CODE='POO'
	LEFT JOIN b_iblock_property FP12 ON FP12.IBLOCK_ID = B.ID AND  FP12.CODE='IP'
	LEFT JOIN b_iblock_property FP13 ON FP13.IBLOCK_ID = B.ID AND  FP13.CODE='STATUS'
	INNER JOIN b_iblock_property FP14 ON FP14.IBLOCK_ID = B.ID AND  FP14.CODE='CLUSTER'
	LEFT JOIN b_iblock_element_property FPV0 ON FPV0.IBLOCK_PROPERTY_ID = FP0.ID AND FPV0.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV1 ON FPV1.IBLOCK_PROPERTY_ID = FP1.ID AND FPV1.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV2 ON FPV2.IBLOCK_PROPERTY_ID = FP2.ID AND FPV2.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV3 ON FPV3.IBLOCK_PROPERTY_ID = FP3.ID AND FPV3.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV4 ON FPV4.IBLOCK_PROPERTY_ID = FP4.ID AND FPV4.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV5 ON FPV5.IBLOCK_PROPERTY_ID = FP5.ID AND FPV5.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV6 ON FPV6.IBLOCK_PROPERTY_ID = FP6.ID AND FPV6.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV7 ON FPV7.IBLOCK_PROPERTY_ID = FP7.ID AND FPV7.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV8 ON FPV8.IBLOCK_PROPERTY_ID = FP8.ID AND FPV8.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV9 ON FPV9.IBLOCK_PROPERTY_ID = FP9.ID AND FPV9.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV10 ON FPV10.IBLOCK_PROPERTY_ID = FP10.ID AND FPV10.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV11 ON FPV11.IBLOCK_PROPERTY_ID = FP11.ID AND FPV11.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV12 ON FPV12.IBLOCK_PROPERTY_ID = FP12.ID AND FPV12.IBLOCK_ELEMENT_ID = BE.ID
	LEFT JOIN b_iblock_element_property FPV13 ON FPV13.IBLOCK_PROPERTY_ID = FP13.ID AND FPV13.IBLOCK_ELEMENT_ID = BE.ID
	INNER JOIN b_iblock_element_property FPV14 ON FPV14.IBLOCK_PROPERTY_ID = FP14.ID AND FPV14.IBLOCK_ELEMENT_ID = BE.ID
WHERE 1=1
	AND (
		((((BE.IBLOCK_ID = '47'))))
		AND ((((FPV14.VALUE_NUM = '156972'))))
	AND (((BE.WF_STATUS_ID=1 AND BE.WF_PARENT_ELEMENT_ID IS NULL)))
Запрос типовой, и не должен вызывать проблем, но вот на 2х серверах из 3х почему-то зависает на 1+ минуту, а зависает именно сбор статистики (statistics 99% времени):
profile
variables
explain
Что пробовал:
CHECK TABLE, analyze, optimize
В чем может быть проблема?
    #39775166
supermike
Да и забыл написать, что на том сервере где проблема не наблюдаетсЯ, запрос выполняется менее 1с, а мощности у серверов +- одинаковые. А вот конфиги могут отличаться.
