mariadb перегружается
лог автор2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Using mutexes to ref count buffer pool pages 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: The InnoDB memory heap is disabled 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Compressed tables use zlib 1.2.7 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Using Linux native AIO 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Using SSE crc32 instructions 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Initializing buffer pool, size = 4.0G 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Completed initialization of buffer pool 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Highest supported file format is Barracuda. 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Starting crash recovery from checkpoint LSN=52460446021 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Restoring possible half-written data pages from the doublewrite buffer... 2020-07-18 10:12:37 139777267579136 [Note] InnoDB: Starting final batch to recover 229 pages from redo log 2020-07-18 10:12:38 139777267579136 [Note] InnoDB: 128 rollback segment(s) are active. 2020-07-18 10:12:38 139777267579136 [Note] InnoDB: Waiting for purge to start 2020-07-18 10:12:38 139777267579136 [Note] InnoDB: Percona XtraDB ( http://www.percona.com) 5.6.47-87.0 started; log sequence number 52460776170 2020-07-18 10:12:38 139777267579136 [Note] Plugin 'FEEDBACK' is disabled. 2020-07-18 10:12:38 139777267579136 [Note] Recovering after a crash using tc.log 2020-07-18 10:12:38 139771502364416 [Note] InnoDB: Dumping buffer pool(s) not yet started 2020-07-18 10:12:38 139777267579136 [Note] Starting crash recovery... 2020-07-18 10:12:38 139777267579136 [Note] Crash recovery finished. 2020-07-18 10:12:38 139777267579136 [Note] Server socket created on IP: '::'. 2020-07-18 10:12:38 139777267579136 [Note] /usr/sbin/mysqld: ready for connections. Version: '10.1.45-MariaDB' socket: '/var/lib/mysql/mysql.sock' port: 3306 MariaDB Server только не пойму- падает и сразу стартует? логичнее чтобы упала и все никаких ошибок про нехватку памяти не вижу как определить причину? ... |
| 18.07.2020, 13:22 |
Для идей данных недостаточно. Вы показали лог запуска. А есть лог остановки? Или процесс жестоко отстреливается так, что в лог ничего не пишет? Если жестоко - то должна быть запись в системном логе. Есть еще вариант падения в кору без каких-либо записей. zizi_top только не пойму- падает и сразу стартует? логичнее чтобы упала и все ... |
| 24.07.2020, 02:17 |
start [/forum/search_topic.php?author=tiagat&author_mode=last_posts&do_search=1]: |
63ms |
37ms |
| others: | 1665ms |
| total: | 1869ms |
